Question about Conair GS33R Compact Fabric Garment Upholstery Steamer, 1000W, 30Minute Steam, Freshen, Remove Wrinkles Odors, Kill Dust Mites, Door Hook, Handle
My GS23R fabric steamer does not work.
Its brand new, and I've tried the water/vinegar ratio and it still does not steam...
  • JOsh Walter Nov 20, 2014
    Hi Rachel Wldnr, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Novelist:
  • 194 Answers
Time to return under warranty. There are no user serviceable parts.
Posted on Nov 13, 2014
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Jul 08, 2014 | Rowenta Commercial Garment Steamer - White
How to remove mineral build up fron steamfast sf-465
Alternatively, use in your steamfast
  1. Fill the steamer with an equal part solution of water and household vinegar and let this soak for an hour.
  2. Once the hour is up, shake steamer to adgitate
  3. Then, empty the steamer and add a couple cups of mixture through machine.
  4. If you don't have any vinegar to hand, try lemon juice!
Organic Cleaner White Vinegar For Calcium and Mineral Build Up
Removing Mineral Deposits from Household Surfaces
How to Remove Mineral Deposits
Apr 15, 2014 | Steam Fast SF-465 Iron
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
My toastmaster iron has a steam button and a spray button. They will not work. Should I clean the iron out with vinegar?
You can try to remove the spray nozzle if it unscrews and soak it in vinegar or CLR (Calcium,Lime,Rust available at stores) solution. Yes or use vinegar water mix 1/4 c vinegar 2 c water, or again there are products that are made for iron cleanout but vinegar is the least chemical based and cheaper. Fill the sprayer with the solution, and the steamer also. Operate the iron on the highest steam setting and iron on a folded towel to clean it out. You may have to scrape out the scale build up from the sprayer if it wont clear with the solution.
Feb 20, 2010 | Toastmaster Irons
Hardly any steam comes out...hose is getting pretty hot...How do I clean it out..Iv'e had it for a while.
Soak the nozzle in white vinegar for 10-15 minutes. Dip it into plain water to rinse the vinegar out. The deposits in the nozzles will be melted away.
Oct 29, 2009 | Rowenta Commercial Garment Steamer - White
My steam iron will not steam. How do I clean it?
Mix (1 to 5 parts) white vinegar in distilled water and pour into the reservoir. Let sit for an hour or so, then pour out through a coffee filter into a container, then pour back into the iron for another hour. At this point, heat the iron and try the steamer function. The vinegar solution will clean deposits from the steam jets, so don't try to iron anything yet. Keep running solution through until sputtering stops. Wash out the reservoir with distilled water, then refill and steam wash the ports several times to remove the vinegar. If you can get it clean, continue to use only distilled water in the iron.
Sep 07, 2009 | Irons
The steam on my FP-202L stop working. I believe it may be caluicm buildup, even though I use distill water. How do I clean the caluicm out?
I've heard that Vinegar is the best for water applicances, like steamers, coffee makers, Irons, etc.
Try rinsing it out with vinegar.
Jul 28, 2009 | Yamata FP202L Cordless Iron with Auto...
IS8100 Commercial Steamer is leaking water
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Dec 24, 2008 | Rowenta Commercial Garment Steamer - White
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Conair GS33R Compact Fabric Garment Upholstery Steamer, 1000W, 30Minute Steam, Freshen, Remove Wrinkles Odors, Kill Dust Mites, Door Hook, Handle Logo
688 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Conair Iron Expert? Answer questions, earn points and help others
