Question about Microwave Ovens
I have a magic chef over the stove microwave. It sparked underneath when I was using it, it does not turn or heat food nor does the light. But everything else works the keypad,the vent and the clock. It sounds like it's working when you turn it on. Help
    Novelist:
  • 167 Answers
Sounds like the high-voltage magnetron (the heating unit) is not getting power. It could be as simple as a broken wire inside the unit (which would explain the spark) or a failed control board or high-voltage power supply (which also might let go with a spark).
Posted on Nov 06, 2014
5 Suggested Answers
SOURCE: Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Posted on Feb 12, 2009
Obertelli
  • 3006 Answers
SOURCE: My microwave oven isn't heating my food.
This is typical of a failed magnetron: the part which actually supplies the microwaves.
By their very nature magnetrons can fail without warning from the day of manufacture but the vast majority do last longer than the manufacturer's warranty. I have noticed a trend towards more frequent premature failure with increasingly powerful ovens.
If the magnetron has failed then there is nothing you can do to fix this as it must be replaced. It's also typically the most expensive single component in most ovens so is rarely an economic repair.
Your appliance should still be within the manufacturer's warranty so you should follow their advice regarding getting the oven repaired. If you're in the UK then you have Sale of Goods Act protection for up to six years from the purchase date and if you wish can insist that the retailer replaces the oven or refunds your money as the goods were not "of satisfactory quality".
Posted on Oct 16, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Posted on Apr 06, 2010
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
Model #MCO2212ARB (black) microwave doesn't heat food - fan, light all work well just doesn't heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 15, 2010 | Magic Chef Microwave Ovens
Will not heat up but it turns on and runs
the light won't come on how can i get the light bulb out?
Jun 24, 2010 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
Jun 14, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave oven not functioning
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Dec 04, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
