Question about PANDIGITAL 8.5"x14" WiFi Portable Wand Scanner & Software - Black -
How do I clear the scanned items out of the scanner that has its own built in memory?
I scan to my computor. do it just right. But how do I get the stuff cleared from the scanner.
    Problem Solver:
  • 7 Answers
Are you sure it is saving it even after you turn it off and back on? Does it save it in a buffer until your next scan? What does the manufacturer's website or the instructions say?
Posted on Nov 16, 2014
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
Scan says all channels locked out
Please try this,
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps!!
Happy Scanning
Nov 22, 2012 | Radio Shack Pro-97 Handheld Scanner
I have a nissian skyline 2004 Engine light is on and miss fires under load this started imediately after the battery was flatten due to headlights being left on. is there some way to reset the computor?
Check for the nearest chain auto parts store, call them and ask about a free scan of your computer, all offer it to my knowledge. The scanners also have a reset function built-in. Detaching the battery might work but if the problem started from a dead battery, it will not likely work with your vehicle and can require dealer help to get stereo or other accessory items working again.
Jun 22, 2012 | Nissan SKYLINE Cars & Trucks
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
My HP 5300 C scans the items but when I try to open them they look like colors are missing. This happens on both black and white items and color items. What I get are shades of purple?
For Precisionscan scanning software, delete HPCCOPY files and reinstall the scanning software.
  1. From the Windows Desktop, select Start , Find , and Files or Folders .
  2. Type HPCCOPY.* in the Named box and C: in the Look In box. Click Find Now .
  3. When the files appear, select all the HPCCOPY files; right-click and select Delete .
  4. Reinstall the HP scanning software.
  5. Shut down the computer, cycle power on the scanner and turn the computer back on. The error should no longer occur.
For Precisionscan pro scanning software, delete HPIPCOPY files and reinstall the scanning software.
  2. Type HPIPCOPY.* in the Named box and C: in the Look In box. Click Find Now .
  3. When the files appear, select all the HPIPCOPY files; right-click and select Delete .
Feb 01, 2011 | HP ScanJet 5300C Flatbed Scanner
How do I scan to the computer?
The exact steps to scan will depend on what software you're using. Windows itself has a "Scanner and Camera Wizard" that you can use. Most scanners come with software that gets installed along with the necessary drivers when you run the installation CD. (You do have a properly installed scanner connected, right?)
In general, the steps in scanning are:
  1. Place the item to be scanned on the scanner.
  2. Start the scan software.
  3. Do a preview scan.
  4. Select any scanning options and the scan area as applicable.
  5. Scan the item.
  6. Tell the software to save the image if it's not automatically saved for you.
The fine details will vary, but that's basically all there is to scanning.
Nov 28, 2010 | Computers & Internet
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
The library is using APEXII scanner to scan collection for
It might depend on your application, but I'd try downloading all the information you scanned more often than every 20K items. It's possible that you are filling up the memory in the unit and it won't accept any more.
May 21, 2010 | Compsee Apex II
We have a HP Photosmart C6280 All in One Printer/Scanner/copier. We want to scan to computor.The menu only shows "scan to copy" and "scan to memory card" The manual that came with the...
If possible, find the software disk that came with the printer, and reinstall. One of the options should be to scan from the scanner to the computer. Just make sure that option is selected on re-install, and that the necessary communication cables for that option are installed.
Nov 19, 2008 | HP Office Equipment & Supplies
Benq scanner 3300u
hi dear castemer my softwar missing so give me this software
realy all good use full ok
thank you
Sep 09, 2008 | BenQ Scan to Web 4300U Flatbed Scanner
PANDIGITAL 8.5"x14" WiFi Portable Wand Scanner & Software - Black - Logo
Top PANDIGITAL Computers & Internet Experts
brian soufane
Josh Whitehead
Josh Whitehead
Are you a PANDIGITAL Computer and Internet Expert? Answer questions, earn points and help others
