Question about Microwave Ovens
I have a manicured over the stove microwave. It sparked underneath while I was using it. The micro won't turn or heat food and the light work but everything else does work the keypad the vent and the clock that all works
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Its fried, the magnatron is toast
Posted on Nov 06, 2014
I have a magic chef over the stove microwave. It sparked underneath when I was using it, it does not turn or heat food nor does the light. But everything else works the keypad,the vent and the clock. It...
Sounds like the high-voltage magnetron (the heating unit) is not getting power. It could be as simple as a broken wire inside the unit (which would explain the spark) or a failed control board or high-voltage power supply (which also might let go with a spark).
Nov 06, 2014 | Microwave Ovens
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
Top stove micro wave-everything works but do not heat the food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 09, 2011 | Frigidaire FMV156D Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Microwave sparked out now it does not work
You had something metal inside the microwave. Do you have a rack inside on a revolving tray? On my microwave, if the foot of the wire rack is not on the revolving tray, it will spark against the floor of the oven. Microwave will go around round pieces of metal - it will spark if it finds a flat surface. I dont think you did any damage to your machine but try to not do this again.
I hope this helps you.
Sep 08, 2009 | Microwave Ovens
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
My KCMS185JSS-5 microwave has no heat. It seems to be running, the light and turn table all work, but it won't heat water.
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
Jun 15, 2009 | KitchenAid Microwave Ovens
Short circuited Whirlpool MH1150XM while changing the bulb underneath. Need help to fix it, thanks :)
We replaced the board behind the control panel. $130.00. If you do this make sure you can put the wires back the right way. My husband finally got it and our micro is working like brand newThanks to all who tried to help.
Sep 29, 2008 | Whirlpool MH1150XM Convection/Microwave...
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
