Question about Dryers
Panel light don't come on, drum light ok, dryer won't start.
Front panel light don't come on, drum light ok, dryer won't start. Could this be the electronic board. Could this be door switch related - if so how would one access the door switch? I removed top but saw that you couldn't get to the switch easily and I couldn't easily remove the cowling under the water tank to gain access. If I supplied poer to the electronics board where the power plug clips on, should the panel lights come on? Any one got a wiring diagram for this unit? Thanks
SOURCE: How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Posted on Mar 19, 2008
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
  • 4 Answers
SOURCE: remove front panel of maytag MDG7400Aww gas dryer
You have to remove the front panel first to access the clip that holds the front of the top down. Instructions:
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  4. This has exposed the interior.
Posted on Nov 01, 2008
  • 6 Answers
SOURCE: DRYER FIN IN DRUM IS COMING LOOSE
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
Posted on Jan 07, 2009
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
Dryer drum won't spin
the front control panel has 2 little screws on the 2 top corners remove them, then pry off the entire control panel (very careful ) once the panel is off remove 4 screws that hold the front to the body, then open the door and remove the 2 screws in front next to the lint filter, slowly remove the front door assembly starting from top, disconnect the door switch, then lift it off the front hooks and the door is out, then remove the front 4 screws from the front bearing and remove, so will gain access to the blower housing, good luck
Apr 11, 2012 | LG Dryers
Dryer heats, but won't tumble. Suggestions?
Either there is no tension on the belt or the motor is not running. If you don't hear the motor, the first thing to check is whether any air blows out the vent. If you have air moving, the motor is OK and you can check for a broken belt or a problem with the tensioner pulley mounted on the motor bracket. First, reach inside the dryer and try to turn the drum by hand. If it turns very easily, belt tension is definitely the problem. If you can't turn it at all and the dryer was previously making a lot of noise, the drum has crashed due to a bad bearing or bushing pad. A stuck drum can also ruin a belt.
On most dryers, you can remove the panel under the door to look at the motor and belt tensioner. Usually you have to take off the floor trim piece way down at the bottom, then remove the screws holding the panel. The top of the panel is commonly held in place with spring clips.
On some models you have to undo screws at the back near the top, then tilt the top up like the hood on a car (there are spring clips holding the front of the top; you may need to pry with a thin piece of hardwood or a screwdriver with tape wrapped around the shaft to protect the paint on the dryer). This gives you access to clips and screws holding the front onto the dryer. If you have a broken belt, you'll need to remove the front (door assembly) anyway to replace the belt or drum bearing. (Some models have a drum bushing on a center pin in the back of the dryer; you can get at these by removing a plate on the back).
If the tensioner pulley has a lot of slop in the bearing, fix this; otherwise the belt may wobble off it again. You'll be surprised by how much quieter the dryer gets.
If the motor is not running, check for a failed starter capacitor (located inside the control panel), a bad centrifugal switch (inside the motor), bad contacts in the timer (control panel), or an open thermal fuse in the motor.
CAUTION: unplug the dryer before doing any work inside.
Jun 06, 2011 | Dryers
I don't have a repair manual for White Westinghouse dryer. Need to replace heating element. Not sure how to get to the element
Instructions
    • Disconnect the power cord from the electrical outlet before servicing the Westinghouse dryer.
    • Insert the putty knife into the gap above the front panel and below the top panel. Lift the putty knife handle up to unfasten the internal locking clips.
    • Lift the top panel from the dryer cabinet. Rest the panel on the wall behind the dryer.
    • Remove the two screws on the top border of the front panel. Lift the front panel straight up to unhook it from the dryer cabinet. Unplug the connector leading into the front panel. Set the front panel aside.
    • Move the idler pulley arm toward the front of the dryer cabinet to loosen the belt. Remove the belt from the drum and pulleys.
    • Lift the drum out of the dryer cabinet.
    • Disconnect the electrical plugs leading into the heating element. Unfasten the screws securing the element to the inside of the cabinet. Lift the element out of the cabinet.
    • Place the new heating element inside the dryer. Connect the screws holding the element to the cabinet. Plug the electrical connectors into the element.
    • Reposition the front panel. Plug the door switch connector into its socket on the front panel. Press the panel straight down into the base. Reinstall the screws along the top of the panel.
    • Lower the top panel onto the dryer. Press down on the panel to lock it into place
May 12, 2011 | Dryers
MAYTAG DRYER MDE3757AYW MAKING CLANGING NOISE CONSTANTLY WHILE DRYING ANYTHING FROM TOWELS TO SHEETS, ETC. SOUNDS LIKE PIECES OF METAL LOOSE. NOTHING ABNORMAL IS IN THE DRYER SUCH AS BUTTONS, ETC....
Sounds like the drum roller supports are warn out. Unplug the dryer. Remove the two screws on the lower front panel and tilt the bottom of the front panel out and remove the front panel. Mark and remove the wires going to the door switch. Set the front panel aside. Remove the four screws holding the drum shroud and lift up and out. Set to one side leaving the wires attached. Go to the rear of the dryer and remove the small access panel, Remember how the drum belt is attached to the tension spring loaded pulley and motor pulley. Remove the belt from this assembly and go to the front of the dryer and remove the drum. The drum rollers are located on the rear bulk head of the dryer. Check to make sure that they spin ok or if they are warn out. Replace both rollers. Check the glides on the front shroud. These are teflon glides that the main drum ride on. IF warn, replace glides. Reassemble the dryer in the opposite way in which it was disassembled.
I hope this is of some help.
Jan 25, 2010 | Maytag Dryers
GE model DQSR483EE1WW. This is what I know so far: the switch on the door works so it shouldnt be that safety, it is getting power because the light work and the timer at least buzzes like its working,...
Try looking for a broken belt. (electrical interlock prevents starting with broken belt) Disconnect power, open door, remove two phillips screws which go from top of door opening into dryer top. Swing top up and back. If belt not present going around drum, that's your problem. Remove one screw from side panel to front panel on each side (near top) and lift front panel forward and off the bottom pegs. Set the front panel to the side (leaving door switch wires attached) so you can slip new belt around drum. Reach under drum to put belt WE12M29 around drive pulley and around tensioning pulley. (grooved side of belt touches drum) Put front back on dryer and manually rotate drum a couple revolutions to make sure belt does not come off before closing up top and reconnecting power.
Dec 24, 2009 | Dryers
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Dryer won't start
It sounds like you have a blown thermal fuse. Searspartsdirect.com has a replacement kit available. Just type in your model number and the kit can be located under the "Heater" heading as item number 5 (part #LA-1053). The kit contains the hi-limit thermostat and thermal fuse. Replace both components at the same time. NOTE: Only one of the thermal fuses will be used, however. One is for a GAS dryer, while the other is for an ELECTRIC dryer. They are marked accordingly.
To access, you will need to remove the dryer front panel. This is accomplished by inserting a putty knife into the seam where the dryer top and front meet (about 2 inches in from each end) and pushing in to depress the release tabs. Disconnect the door switch wires and the front panel comes off and can be set aside (make sure you label the wires). With the front panel removed, the dryer top panel lifts up. The heating element will be located in the center-rear of the dryer behind the dryer drum.
If you require further assistance, please let me know. I hope this information is helpful to you.
NOTE: The website also includes helpful illustrations for component location and wiring diagrams. The correct wiring diagram depends on your dryer serial number. If you have questions about this let me know (send me the serial number).
Jun 17, 2008 | Dryers
Dryers Logo
43 people viewed this question
Top Dryers Experts
