Question about Coffee Makers & Espresso Machines
HelP! I am looking for a rocker switch for a drink cup sealing machine. R13133DC 12 volt 30 amp. please. Can someone call me at 541-729-3670, or e-mail me @ jr48buzz@aol.com
I need a rocker on and off switch for a cup sealing machine Model No. F 06 that fits on an MTN control board. This switch has got a post that screws on with a nut. The number on the switch is R13133DC 12 volt 30 amp. Can you please help me. Thank you, Jim Ray 541-729-3670
  • 1694 Answers
SOURCE: I need a code for unversial remote
Try www.remotecodelist.com Hope that helps......T.
Posted on Jan 02, 2008
SOURCE: tru tech television
um k
Posted on Aug 30, 2008
  • 37 Answers
SOURCE: USED 10 CUP MODEL
Hi Dave,
The manual was just emailed to you.
Thank you.
irene@smithagy.net
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: Where is the driver side power window cicuit breaker.
check the wireing to the window motor an at the conector as well where it comes thru the door =- i have seen them break there an its covered === also check the circuit breaker in the fuse pannel position number 16 in the breaker for the window motors ok
dennis
Posted on Dec 12, 2008
Jay_from_Ma
  • 99 Answers
SOURCE: RADIO CODE FOR '06 HONDA RIDGELINE
You will need to remove the radio from the das, and get the numbers off the back of it. Then you will need to call a honda dealership with your vin number and the numbers off the back of the radio. they will be able to get the code for it. The reason being, is for security, like if your radio was stolen a thief couldn't just reactivate it without the proper info.
Hope this helps!
Posted on Dec 17, 2008
On a 3.8L what is the aspec diagram and tourque for the racker arm
Hi Juan, I'm AL the owner of Big As Auto Repair
Below is the torque specs for the rocker arm as you requested.
SPECIFICATIONS - TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sprocket-Bolt 54 40 - Camshaft Thrust Plate-Bolts 12 - 105 Forged Connecting Rod Cap-Nuts 54 +¼ turn 40 +¼ turn - Cracked Connecting Rod Cap-Bolts (Refer to 9 - ENGINE/ENGINE BLOCK/PISTON & CONNECTING ROD - INSTALLATION) Crankshaft Main Bearing Cap-Bolts 41 +¼ turn 30 +¼ turn - Crankshaft Main Bearing Cap Cross Bolts (3.8L) 61 45 - Crankshaft Oil Seal Retainer Rear-Bolts 12 - 105 Crankshaft Damper-Bolt 54 40 - Cylinder Block Drain Plugs 20 15 - Cylinder Head-Bolts (Refer to 9 - ENGINE/CYLINDER HEAD - INSTALLATION) Cylinder Head Cover-Bolts 12 - 105 Flex Plate to Crankshaft 88 65 - Engine Mounting (Refer to 9 - ENGINE/ENGINE MOUNTING) Powertrain Torque Strut 54 40 - Exhaust Manifold-Bolts 23 - 200 Exhaust Crossover Pipe-Bolts 54 40 - Intake Manifold - Lower-Bolts 23 - 200 Intake Manifold - Lower Gasket Retainer-Bolts 12 - 105 Intake Manifold Upper-Bolts 12 - 105 Lifter Yoke Retainer-Bolts 12 - 105 Oil Filter Attaching Fitting 54 40 - Oil Cooler Attaching Fitting 27 20 - Oil Filter 20 15 - Oil Filter Adapter-Bolts 28 - 250 Oil Gallery Plug 27 20 - Oil Pan-Bolts 12 - 105 Oil Pan Drain-Plug 27 20 - Oil Pressure Switch 23 - 200 Oil Pump Cover Plate-Screws 12 - 105 Oil Pump Pick-up Tube-Bolt 28 - 250 Oil Dipstick Housing-Bolts 48 35 - Rocker Arm Shaft-Bolts 23 - 200 Spark Plug 16 12 - Thermostat Housing 12 - 105 Timing Chain Case Cover -M8 Bolt 27 20 - -M10 Bolt 54 40 - Water Pump-Bolts 12 - 105 Water Pump Pulley-Bolts 28 - 250
Should you need extra help visit my website here: http://www.bigasautorepair.com/
Apr 15, 2015 | 2005 Chrysler Pacifica
30amp auto shutdown fuse blows is it alternater
The ASD relay supplies battery voltage (12+ volts) to the fuel injectors and ignition coil(s). With certain emissions packages it also supplies 12-volts to the oxygen sensor heating elements. The Fuel Pump Relay is a separate relay controlled by the ASD relay input to the PCM. Fuse #12 (10amp) provides 12 volts to the coil side of both the relays and the ignition switch. Fuse #6 (30 amps) supplies 12 volts to the output side of the relay. Fuse #16 (15 amp) from the relay output to the Oxygen Sensors and Fuse #26 (15 amp) relay output to the PCM. Fuse #24 (20 amp) is Fuel pump relay output to fuel pump. Fuse #19 (10 amp) supplies 12 volts direct to the PCM.
look for burned or melted wires in the offending circuit.
sounds like you wiggled a wire while installing new relay.
Mar 06, 2013 | Cars & Trucks
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
2000 grand am. replaced relay, fuse, and fuel pump. still is not getting fuel to fuel rail. 5 volts is present at fuel pump but not 12 volts to run pump. reset passlock.....still do not have 12 volts at...
Pull the relay and make sure you have 12 volts there. Pin # 30 is the power to the pump. this will tell you which way you have to go to find a short or corrosion in the wires. let me know
Randy
Nov 27, 2010 | Pontiac Grand Am Cars & Trucks
Looking for the on/off switch
I've replaced the power switch/button on a Black & Decker SmartBrew coffee maker (DCM2000).
I used an illuminated rocker switch from NTE Electronics rated at 16A @ 125 VAC, part number 54−531.
This switch cost me $3.12 CDN + taxes.
http://www.nteinc.com/switches/pdf/illuminated_rocker.pdf
The pinouts on this switch are the same as the rocker switches/power buttons used in the basic Black & Decker Smartbrew coffee makers.
You can simply cut out the old switch and attach this one to the wires in the same order, as indicated by the square notch on the body of the switch/gold terminal.
May 19, 2010 | Black & Decker Smart Brew Plus 12 Cup...
My gevalia coffee maker just doesn't turn on anymore. worked fine the day before, the next morning went to use and it didn't work.
Open the thing up and look for loose connections or a short or loose ground wire. Go to electronics shop and buy a new rocker switch for it.
Feb 15, 2010 | Gevalia CM-500 12 Cup Coffee Maker
Hello, I have a 12 Volt coffee cup warmer. One
look at the end of wire and see what type of connector it is,now look for a terminal that does not have a wire on it ,if you see one then look very close at it to see if there are any marks or scratches on it .If it does you have found it ,if it dont keep looking for another one.I wouldnt think there would be to many places it could go.
Mar 21, 2009 | Electrical Supplies
dennis
Nov 23, 2008 | 1996 Chevrolet Cavalier
The convertible top stop working
I HAVE 1994 FORD MUSTANG TOP COVERTABLE TOP NOT WORKING FUSS ARE GOOD I CHANGE THE RELAY IN THE TRUNK.I REPLACED THE CONVERTABLE MOTER IN THE TRUNK WHAT ELSE ARE THEY TO DO
Jul 29, 2008 | 1994 Ford Mustang
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
