SOURCE: how to forward calls using KX-T7633 ?
press 'program' - at the top of the phone
enter 50
press ' enter'/ auto dial store
enter 4
enter the extension you wish to transfer call to
press auto dial store
to take call forward off
press program
enter 50
press 'enter' auto dial store
press 0
press auto dial/ store
this should work!
SOURCE: changing time on PAnasonic KX-T7633?
This is what worked for me :
program, **, passw 1234, you change the time/date, and then to store, press Autodial or store button.
Hope this helps!
Caroll
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
SOURCE: I have inherited a KX-T7633 and cannot access
It depends on what you mean by "can't access". The Panasonic voice mail system is accessed by dialing the VM access code, sometimes 500 or 165, from the phone you want to use. If you, for example, are extension 105, and it has a voice mail box, the lady will either tell you how many messages you have, or ask for a password. If that's how you can't access VM because you don't have a password, then the password can be reset from mailbox 999, the system administrator's mailbox.
There are two passwords YOU ABSOLUTELY HAVE TO HAVE. If you don't know the passwords to 998 and 999, then you will have to get them from the original installer, or call your Panasonic dealer. Alternatively, if you have the VM maintenance console password, you can reset 998 and 999's password.
Carl
SOURCE: change my extension name KX-T7633
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.-
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 004 and then ENTER.
3. Enter the extension number you want to change.
4. Enter the name (the same way as texting on a cellphone)
5. To save the changes press AUTO DIAL / STORE.
6. To go to the next extension press NEXT on the screen.
7. Lift the handset and put it down to exit program mode.
