Question about Mallory 1986-1992 Buick LeSabre Fuel Pump, 87-91 4259FI
Where is the feul tank location on 1986 buick park ave?
I cannot find the feul pump or the feul pump relay or feul tank on 1986 buick park avenue 6cyl 4 speed automatic
    Scholar:
  • 103 Answers
The fuel pump is located inside the fuel tank. The tank will have to be emptied and removed to get to the access cover on the top of the fuel tank.
Posted on Dec 12, 2014
Heater fan runs with ignition switch off where is fan relay located
I think the fault is with the radiator temp censer , it acts as a on off switch, located on the radiator tank.
Sep 04, 2014 | 1994 Buick Park Avenue
Where ios the horn fuse or relay located
1993 Buick Park Avenue 3.8L SFI OHV 6cyl
The Horn Relay is located: Under hood, center, upper firewall, passenger side of blower motor, mounted in relay block.Here's what it look's like Ken. Duralast Relay Radiator Cooling Fan Motor 19272 1993 Buick Park Avenue...
Apr 07, 2014 | 1993 Buick Park Avenue
Where is the fuel pump relay located on a 1993 buick park ave
Dear Actken,
I Believe Is Under The Dashboard, Right Underneath The Glove Compartment.
Hope This Helps.
Alex :o)
Nov 11, 2011 | 1996 Buick Park Avenue
Where is the fuel pump on a 1997 park ave buick
The fuel pump is electric and located in the fuel tank. The tank will need to me dropped to service the fuel pump.
Oct 06, 2011 | 1997 Buick Park Avenue
Where is fuel pump located on a 1991 buick park ave
The fuel pump is located inside of the fuel tank on that vehicle.
Aug 20, 2010 | 1991 Buick Park Avenue
Where is the fuel tank located in a 1991 buick park ave?
Gas tank is located inside of fuel tank. Loosen the two straps on tank and let the tank drop slowely with floor and wood support underneath.(make sure gas is removed so it is not so heavy) Lower tank and remove electrical wire connections and remove filler hose from tank side.Remove tank from car. Tank has round o ring lock on top.Take rubber malet and tap o ring counter clockwise to remove pump assembly replace pump and then use reverse procedre to put tank back.Good luck.
Where is the fuel filter located?
On 1994 Buick Park Avenue 3.8L SFI OHV 6cyl the Fuel Filter is located: There are two possible locations for this component due to variation in production under vehicle, passenger side, front of fuel tank, mounted on frame in fuel line or under vehicle, driver side, front of fuel tank, mounted on frame in fuel line.
Hope helped (remember comment and rated this).
Apr 10, 2010 | 1994 Buick Park Avenue
93 buick Park ave ultra wont start. Turns over fine, but wont start. Was sitting awhile, 2 months. Ran o/k before that.
make sure there is gas in tank. turn ignition switch to the on position.listen for fuel pump.if yes check for spark at plugs.if no you dont hear fuel pump.check fuse and relay.if both dont work.scan it to check for faulty crankshaft sensor fuel pump and pcm.
Jul 18, 2009 | 1996 Buick Park Avenue
What is the llocation of a fuel pump for a1988 buick park avenue
the fuel pump like all pumps on fuel injected cars is in the fuel tank.
Jan 14, 2009 | 1994 Buick Park Avenue
Can you please tell me which relay is for the fuel pump in a 1994 Buick Park Ave? Thank you.
your fuel pump relay is located on the passenger sid kick panel, small relay on bottom
Mallory 1986-1992 Buick LeSabre Fuel Pump, 87-91 4259FI Logo
351 people viewed this question
Top Mallory Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Mallory Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
