Question about Dishwashers
What clearance do I need between the wine cooler and surrounding cabinets and counter top?
This is a free standing unit
    Problem Solver:
  • 12 Answers
According to "Air-n-Water.com," the rule of thumb for non-front ventilating, free standing units is a 3" clearance all around. Hope this hel
Posted on Nov 06, 2014
What is my clearance regulations for
Hello Donna;
My name is Peter. I am a retired field service refrigeration technician.
The critical clearance, especially with under the counter units is in the back. You need extra space between the back wall and the heat coming off the compressor. I like to see 3" minimum. The more the better. If you are not getting sufficient air flow in the back then, your cooling condenser coil fan will constantly run in a effort to dissipate the heat.
Most manufactures recommend 1-1/4" minimum on the sides.
Nov 06, 2014 | Soleus JC-128 Wine Cooler
How do you open cabinet to replace fans on a Breezaire WK2200 unit?
YOU WILL HAVE TO DRILL OF THE RIVETS ON THE SIDES OF THE UNIT USING A 1/8 DRILL BIT, ONCE YOU DRILLED THEM OF YOU WILL TAKE OF THE COVER ON THE UNIT AND YOU WILL SEE BLUE INSULATION ON IT, REMOVE THE TOP INSULATION COVER AND FANS WILL BE EXPOSED, THEY HAVE QICK DISCONNECT LEADS ON THE WIRES, DISCONNECT THE WIRES, UNSCREW THE FANS WITH A PHILLIPS SCREW DRIVER, INSTALL NEW FANS AND REMEMBER TO TIE STRAP THE WIRES FROM THE NEW FANS TOGETHER SO THEY DONT MOVE.
Jul 13, 2014 | Breezaire WKE 4000 Wine Cooler Unit - 1000...
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
What is a build-in wine cooler?
A build-in wine cooler is designed to be built into exiting counter and cabinetry. Build in wine cooler includes a front ventilation system which channels the heat forward from the unit, just like any other wine cooler.
Aug 14, 2012 | Furniture
What is a freestanding wine cooler?
Freestanding wine cooler designed to stand alone without been attached to the wall. Freestanding wine cooler includes a front ventilation system which channels the heat forward away from the unit.
Can I install a freestanding wine cooler under my existing cabinet?
I strongly suggest you find somewhere else for it. Freestanding wine coolers are designed to disperse heat from the back. If you put the cooler under a cabinet, the heat cannot escape and will in time overheat the unit.
Jul 31, 2012 | Furniture
What is the difference between a freestanding and built-in wine cooler?
A freestanding wine cooler is designed to stand alone whereas a built-in wine cooler is fitted into existing counters/cabinetry.
Cannot get temperature below 65F. Probably need replacement cooler unit. Model: AZMN HAL Odyssey Approx Size: 9" H x 15.5" W x 14" D. Serial #: AA4-Odyssey-01201-121
I have never heard of a wine cabinet getting below that range? Has this unit every reach temps that low before? I would make sure the unit is breathing, check the condenser and air flow through the unit. If the unit is not choking, and temps can go below 65, than yes you will need to have it serviced. It can be a thermostat issue.
Good Luck
Jul 13, 2011 | Vintage Keeper Koolspace Wine Cellar
Where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Mar 31, 2009 | Magic Chef MCWC45A Wine Cooler
Clearance??
hi you need at least 3 inchs clearance from the back ribs to the wall for good ventilation if there is no ventilation back there you will need to do 1 if to whole room is hot then you can install a fan that will cool down the heat from ribs good luck
Dec 20, 2005 | Kenmore 13485 Wine Cooler
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
