Question about Coffee Makers & Espresso Machines
Need to fix heater - Coffee Makers & Espresso Machines
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
Buy a new element. or a new machine is there garantee?
Posted on Nov 09, 2014
1996 chevy s10 heater stuck on how do i fix
you probably need to take the heater control panel from the dash and check the switch, or the fan motor itself is bad & stuck on high.
Aug 10, 2012 | Heating & Cooling
Water is over flowing and coming out over the top of my hot water heater, i shut the water off and turned the temp down and turned the water back on after a few hours and water still is over flowing over...
If pipes are leaking, then that can be repaired.
If tank is rusted out and water escaping from the tank, then turn off the water plus power to the heater for safety, and then replace water heater.
Rusted water heater can be welded for repair, but remember that hot water is under pressure and tank can rupture any time.
Safest course if to replace heater.
Open following link for leaking water heater checklist:
http://waterheatertimer.org/Leaking-water-heater.html
Jul 27, 2011 | Whirlpool Water Heaters
How do I increase the water flow on a Jandy LXi pool heater?
You can not increase the water flow through a heater by adjusting the heater. You either need to get a larger pump motor, fix a pump issue, or....
If the heater was installed correctly with a bypass, closing the bypass will force more water through the heater. If a bypass was not installed, a larger motor is needed to increase flow (unless you used to get enough flow and now you dont. I this case, fix the pump or backwash the filter)
Feb 15, 2011 | Jandy LXI 300 PROPANE POOL HEATER -
IR 7200 HEATER SECTION SOUND, & NEARLY HEATER
You need to remove fixing unit and look for broken gears, bushings or security pins on fixing upper roller.
Aug 01, 2010 | Canon imageRUNNER 7200 Copier
DAEWOO MATIZ 800CC 1999 HEATER BLOWING COLD AIR
Or you need anitfreeze.
Or your thermostat is shot. Both are easy fixes.
Try the antifreeze, first,check and top off.
and if teh problem persists, check and repalce the thermostat.
Feb 01, 2010 | Heating & Cooling
Heater core leak hoe do I fix
You will have to remove console, and all the venting and cover to heater core. Then go underneath the vehicle and disconnect both coolant hoses. Then remove heater core. You can go to autozone.com and register for full free online repair manual for your durango with everything you could need.
Dec 09, 2009 | 2000 Dodge Durango
Hi i a maxol MALAGA WATER HEATER gas only in my caravan it is leaking underneath help i need it fixed
If the water heater is leaking you have a rusted tank and it needs to be replaced. Turn off the water till it can be replaced. No fix for a rusted tank has to be replaced.
Jul 23, 2009 | Water Heaters
Heater Coil Leak
Hey mad40bx that will be your heater core,,just pick up a new one and grab a haynes or chilton manual for your truck if you are not familiar with the procedure its not that bad, if you dont need it fixed immediately take the 2 hoses off from the firewall (One is supply and one return) and couple them together this will bypass the heater core until you are ready to fix it, good luck
Nov 09, 2008 | 1988 GMC S-15
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
