Question about Fisher and Paykel DD24DCX6V2 Dishwasher
I have fisher-paykel dd24dcx6v2. At some point upper drawer starts beeping and counting hours
I have fisher-paykel dd24dcx6v2. At some point upper drawer starts beeping and counting hours (at the display is in 01h, 02h ... in cycle). It does not response to front buttons, but does change on Eco and Cycle. Only unplugging power stops it, after power is back on it starts beeping again. Bottom drawer is working fine. Do I need to replace controller ? If so what is the best source. Or I have another options and it switch to some strange diagnostic mode?
    New Friend:
  • 25 Answers
SOURCE: dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Posted on Jan 01, 2009
jyackle5
  • 8197 Answers
SOURCE: Fisher & Pykal Dual Drawer Dishwasher. Suspect
Press and hold the key or lock button for 5 sec or till you here a beep to unlock. Or till the light goes out above the lock button. You can get your manual here just find your dishwasher.
http://www.fisherpaykel.com/dishwashing/
Good luck and please rate
Posted on Sep 16, 2009
SOURCE: fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Posted on Dec 13, 2009
SOURCE: i have bought a fisher and paykel model DW60CSX1
My manual says that this means the drain hose is crimped or bent, or the drain hose is too high. In other words, the drain can't drain for some reason.
Posted on Aug 03, 2010
  • 230 Answers
SOURCE: On the top drawer of the dishwasher the control lights - Heavy, Normal and Eco are all lit up and on the display at the front it says 05 mins the machine keeps going in to a diagnostic rinse cycle and
Unplug the machine and try again. Sometimes resetting the board can solve the problems, other times it's just a faulty board. Good luck
Posted on Sep 06, 2012
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel DD603 - press start and the bottom drawer goes into a 12 second beeping count down delay. At the end of the 12 seconds, it does it again. On button does sound like a "crunch" when pressed....
The display panel has come off the housing. May need to be replaced or refit. Remove front panel to check. Turn mains power off and pull out the plastic clamps from the side with plyer. Careful not to drop any parts on the front panel module. Avoid jerks or too much force.
Sep 30, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Dec 11, 2012 | Fisher and Paykel Dishwashers
Fisher paykel dd603 stops while in cycle and beeps but no error codes show
Does it open the lid?... and does the display flash, as if paused?... if so, just clean the closed sensor lenses, top right hand corner of the drawer, and the little piece of plastic they shine into on the housing.
Nov 29, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD24DCX6V2 Dishwasher Logo
112 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
