How do i connect a commax pre amplifier to a commax amplifier
  • 3,368 Answers
Before somebody can help you you need to give us both the make and model number. You have the unit and know what it is, we don't.
Posted on Nov 27, 2014
Ok, i interested in the technics se a900s amplifier, just for vu meter use, not amplifier,and...
Pre-amp only needed for phono. Otherwise, line in is just fine.
10 to 20 ohm load resisters to substitute for speakers. get 50 watt rated ones at least, they can get hot....
May 12, 2016 | RCA Car Audio & Video
I have an older creek 5350se. It has what appears to be bridging pins connecting the pre with the power sections of the amp. Can I connect the creek as a pre amp to a power amplifier.
Hi Lorne,
You can use the amp as a pre by removing the 'jumpers' - or as a power if required.
The 'jumpers' are simply used to connect (or disconnect) the amplifier's pre & power sections.
Hope this helps.
May 08, 2015 | Creek 5350SE Amplifier
Using turntable (audio technica at-lp 120) with built in pre amp the sound is distorted and broken up. the turntable requests phono turned on to use. Does the receiver have a pre amp or boost signal...
A turn table produces sound voltage in the millivolt range. If you have it connected to a receiver that has a phono input and the turn table is pre-amplified, you are overdriving the receiver and it is clipping the audio and making it sound bad.
Jan 17, 2015 | Yamaha RX-V592 5.1 Channels Receiver
Connect to power amp
plug the bars out plug whatever to the pre in, then the remote out to the power amp.
Dec 07, 2013 | Roksan MkIII Amplifier
I've been given a Technics sl-bd22d turntable, an Arcam amplifier and a Cambridge 551P pre amplifier. How do I connect them all together?
Depends what type of sockets these have. If the Pre-Amp has a RCA phono sockets you just need some RCA leads. I don't know if the Arcam Amp works with any pre-amp. But if it does, it's likely to have the same type sockets as the others. So you just buy another two RCA leads and connect it up.
Apr 19, 2013 | Audio Players & Recorders
The "output" is two RCA
hi,
normally in any amplifiers or pre amplifiers the RCA sockets used only for pre input and output. for speaker out always there will be binding post or speaker sockets, u can connect the pre amps RCA output to ur power amps input. there will be seperate connector for speaker connection in ur power amplifier . You didn't specified the make and model number of ur amplifier and pre. need any further help feel free to contact.
ok
Dec 20, 2010 | Audio Players & Recorders
What is the funtion of tape out, tel, pre amp out , power out, vox, alc... & what is aux dfrs???
Tape out and tape in are to connect the record and playback leads of a tape deck. Pre-amp out is to connect a Power Amp to the unit. The pre-amp will only take the signals from the various sources and amplify them, but only to a weak level. The main reason people would use this is to connect a more powerful amp to the unit.
The Power out could be either the mains power for a turntable or for connecting a pre-amp or maybe to another to amp.
Haven't got a clue to the others sorry!
Sep 04, 2010 | Bogen Communication GS100 Amplifier
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
How to set up an intigrated amp to a 100 watt reciever
audio connection must have matching in audio level and symetrical.
1-prepare your connection cabels(better to be colour marked at connector(red for right channel- white for left chanel).
2-take pre amp right out to power amlifier right in.
3-take pre amp left out to power amplifier left in.
4-connect amplifier right out to right loudspeaker.
5-connect amplifier left out to left speaker.
6-adjust volume level and enjoyyy.
Feb 26, 2008 | Audio Players & Recorders
56 people viewed this question
 Grubhead
Grubhead
