Question about Vacuums
I have a Windsor SRS 15 and I can't figure out how to replace the access door on the bottom where the brushes are it is orange
    Habit-Forming:
    New Friend:
  • 77 Answers
Unplug first. I think it should just snap back in, as long as your brush is correctly assembled. Hope that works!
Posted on Nov 08, 2014
Required Industrial vacuum cleaner heavy duty
For an upright industrial, I would suggest a Windsor or Tennant brand. New ones are cheaper on the Windsor site- both the windsor upright and Tennant upright are made by Windsor (Just like Ford and Lincoln cars are really the same thing- even the part numbers match) Tennant sometimes sells used vacuums. The windsor is the hardest working upright I've seen, and is the easiest to work on/change brushes on. I retired from fixing cleaning equipment after 30 years. Just be sure to get the Tennant with the side hose- it'll last forever.
Apr 05, 2017 | Vacuums
Eureka as1100 roller brush not spinning. We have already replaced the main belt but there is a secondary belt that drives the roller brush and we can't figure out how to access this belt.
Sorry folks, but there's no Eureka with this model no. The model number can be found on a sticker, usually on the bottom of the unit. We'll need the correct model to access schematics of the body so I can tell you how to access the belts.
Nov 03, 2013 | Vacuums
Servicing windsor sensor xp15
You need to replace your beater bar more than likely, if the light stays on all the time. If it is flashing there is usually something jamming the brush roller from turning properly.
Jan 27, 2013 | Winsor Windsor SENSOR XP15 Vacuum
Sensor xp 15 shutting down
If you have one of your red lights flashing or on all the time that will indicate where you need to look for your repair. Beater bar light will indicate a brush roll replacement and the bag light indicates a need to empty the bag or look for a clog somewhere in the air flow area of the hose or wand. These machines are designed to shut down if you keep trying to run them with a red light coming on.
Aug 25, 2012 | Winsor Windsor SENSOR XP 12 Vacuum
My windsor vacuum brush light keeps coming on
You may try a new brush. With these models the light will continuously run to signal it needs the brush replaced.
Jan 29, 2011 | Windsor SR12 Sensor Bagged Upright Vacuum
How do you change the belt on a winsor sensor s12?
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Windsor vacuums.
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Apr 26, 2010 | Windsor SR12 Sensor Bagged Upright Vacuum
I have windsor s12 vaccum this one have brush up light on
The windsor Sensor brush indicator light will come on when:
  • Something stuck in the brushroller
  • Brushroller is worn and needs replacement
  • height is wrong (indicates a problem with height adjustment)
  • a bad circut board/sensor
more than likely your brushroller just needs to be replaced, very common.
Jun 03, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Mar 17, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Kirby G4
Take off the noozle, take off the bottom plate and remove the brush roll and old belt. Check the brush roll while you have it off to make sure the end spin freely. Put the belt on the brus roll and re-install in the noozle, put on the bottom plate. Then turn the big knob on the front of the nozzle all the way, you can only turn it so that the belt catches and will stretch, it will stop when you are all of the way, then re-install the nozzle back onto the Vac, turn that knob back the other way and you are all done.
Jan 05, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
