Question about Refrigerators
Samsung sr20 water dispenser not working - Refrigerators
2 Suggested Answers
  • 167 Answers
SOURCE: Samsung sr20 water dispenser not releasing water
Wait a few hours and try again. Sometimes the water dispenser switch ices up after an auto defrost cycle, especially in humid weather, and it takes a while for the ice to melt.
Posted on Nov 06, 2014
Samsung Refrigerator water dispenser does not work? Ice maker works
The electrically operated valve that opens when you attempt to get water is probably bad. This unit may have one unit with two valves. One each for the ice maker and water dispenser. This valve unit will be in the back of the refrigerator and have a copper or plastic supply line from your house. This line will be "live" so be sure and find and close the valve attached to your house's water supply.
Mar 02, 2015 | Samsung Refrigerators
Nov 06, 2014 | Refrigerators
Water stopped coming out of door dispenser
A few videos about refrigerator water dispensers.
Might not be exactly the same as yours.
Samsung won dispense water YouTube
Oct 05, 2014 | Samsung RF4287HA
Water dispenser not dispensing water
try to change the filter it maybe dirty
Mar 21, 2014 | Samsung RF217ACRS Stainless Steel
Samsung RS275ACWP water dispenser stopped working
Sounds like the pump is faulty but could be the circuit board.
Make sure you have water at the pump. If the pump doesn't start when you call for water it could be even the switch.
This is tricky to explain and would best be repaired by a tech but if you know how to use a multi meter you can easily test it.
Jan 08, 2014 | Samsung Refrigerators
Rf samsung refrigerator
check the relay on the water dispenser you have to open the back cover on the bottom and follow the line or switch them over and see if this will help.
Dec 16, 2013 | Refrigerators
Samsung refrigirator water dispenser works without filter but does not work with filter
Not enough water pressure in supply line to get past filter?
Open valve feeding supply line more and see what happens.
Sep 06, 2017 | Samsung Refrigerators
Water dispenser always dripping on brand new samsung fridge
ring samsung and have one of there service agents come and replace the dispenser now while its under warranty.
Jan 11, 2011 | Samsung Refrigerators
Samsung RS253BABB. Where is the water pump??? I press the switch for the water dispenser and I can hear the pump running but no water comes out. The ice maker works so its getting water to the unit through...
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 21, 2009 | Samsung SRS20DTD Side by Side Refrigerator
Samsung side by side fridge freezer with water and ice dispenser the ice dispenser works fine but the water dispenser dose'nt, I have changed the water valve, It worked for a while but its not working now....
You likely have a blockage in the line somewhere. If the water valve is sending water to the icemaker, it should be sending it to the water dispenser.
Try removing the water dispenser line from the water valve and run something through it to try to open it up. I had this problem several years ago and used a length of plastic weedeater line to open it up.
Oct 20, 2009 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
