Technics SU-G91 volume control does not track when turned and +/- numbers/volume shown/heard.
Turning volume knob varies the volume +/- in a non-linear output. Turning volume control clockwise may turn output down rather than up some times. Turning CCW opposite effect.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
Sorry. I haven't looked this model up, but I have your answer. I'm going to assume this unit is less than 10 to 15 years old. They no longer use, the type of volume control you think of. You can proof this out, by turned the knob left or right. It should probably have no stops, as you remember. That's because this is not a volume control, as in variable resistor. It is called a Rotary Encoder. It is basically two switches that are pushed when you turn the control to the left or right. This creates pulses(actually a high or a low) which go into the display microprocessor(one of the computers inside your unit). When the microprocessor control receiver this input, it controls another IC, called an Electronic Volume Control.
Sorry for the lengthy explanation. The issue lies with the Rotary Control. This is not an uncommon issue for any of the manufactures. This is not a DIY repair. It will require a professional Audio tech. If you need more assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 19, 2014
Technics su-g91 muting is stuck on how do I turn it off
The service manual :http://elektrotanya.com/technics_su-g91_sch_2.pdf/download.html. i can't see it on my ipad. Too fewapps:), read it and if you don't get it, just post it . Btw. Is the mute knob a real push button or which i assume a modern click one?
Sep 06, 2014 | Audio Players & Recorders
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
I have an Technics SU-V3 amplifier when you try to adjust the sound it causes the speakers to crackle(only when your turning it) it is not the speakers as have tried it with several sets of speakers...
It sounds like the volume control itself is causing the problem. All you need do is get to it from the inside the unit and spray it with Servisol switch cleaner. That should do the trick. It's just dust in the track of the control. If there are any other rottary controls spray them too!
Dec 02, 2010 | Technics Audio Players & Recorders
I have a technics su-g91 integrated amp. everything is disconected from it and the yellow over load light is on. What do I do?
hi...i have a electric guitar and i was wondering if i can conect it in my technics su-g91amp?
Nov 24, 2010 | Audio Players & Recorders
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
67 people viewed this question
 Grubhead
Grubhead
