Question about Hamilton Beach 22504 Toaster
Hamilton Beach Model 22504B toaster Springs will not hold down Bread to let it toast
Falling Down
  • 67 Answers
SOURCE: Hamilton Beach 22505 toaster info
Usually, four screws under the bottom remove the top but the toast loader lever knob is usually press fitted on. Some units have bent tabs to hold them together if screws are not used. To remove the knob, freeze the unit (to shrink the knob/lever) then place a flat piece of wood like a ruler wrapped in cloth on the housing behind the knob and use a large bladed screwdriver to try to work the knob off. If you break it superglue and epoxy, and drawer knobs not plastic or wood might work as a replacement.
Posted on Nov 30, 2007
SOURCE: Digital Display no longer showing, lever won't stay down
jsullivan22 is right about the diode. I have this problem with my 24502, which is a dual version of this. There are 2 circuit boards in your unit one with the LED display on it and another one. The diode needing replacing is on the other board. it is in the center of the board, right next to a large (1/2W or 1W) 2K ohm resistor. The diode is probably part number 3ez24d5. Test it with the diode test on your DMM, if it is bad you will get 0V both directions (I think). Also if you measure it with the Ohm function it will probably measure less than an Ohm (check the zero on your DMM as many are not accurate down this low) You can probably replace it with a <a id="ctl00_ContentMain_CartGrid_grid_ctl02_ctl00_lnkManufacturerPartNumber" href="http://mouser.com/Search/ProductDetail.aspx?R=1N5934BGvirtualkey58410000virtualkey863-1N5934BG" style="font-weight: bold;">1N5934BG</a> or a <a id="ctl00_ContentMain_CartGrid_grid_ctl03_ctl00_lnkManufacturerPartNumber" href="http://mouser.com/Search/ProductDetail.aspx?R=1N5359BGvirtualkey58410000virtualkey863-1N5359BG" style="font-weight: bold;">1N5359BG</a> Mouser stocks both of these&nbsp; (currently). I haven\'t gotten my parts so I can\'t guarantee these will work, but I\'m pretty sure. I will try the latter first as I\'m hoping it\'s higher power rating will keep it from burning out again, although I will be buying several spares. <br><br>This is clearly a design issue with these toasters and one that could be easily corrected. Both circuit boards in my toaster are very toasty in the area of these diodes, although I\'m sure the fact that these boards are mounted very close to the heating elements doesn\'t help their longevity.<br><br>Hope this helps everyone.
Posted on Jan 31, 2009
skyblue67
  • 71 Answers
SOURCE: I need the user manual for Hamilton Beach toaster
Hello
you can download a user manual from this site, http://www.retrevo.com/support/Hamilton-Beach-24600-manual/id/19533ag924/t/2/
click on the link or copy and paste link into a browser and on the site look for the download manual link, click on that to download a user manual, save it to your desktop to either print or just to read, this manual is a PDF file, if you do not have the program then you need to download a pdf program first from here and install it following the onscreen instructions after downloading.
http://www.adobe.com/products/reader/
Posted on Jul 28, 2009
SOURCE: I have a H. Beach
I have the same problem. I have troubleshot it down to a transistor or IC on the circuit board with the buttons and rotary control.
The way the toaster works is the board sends a voltage to the electromagnet that holds the "works" down until the desired time or temperature has been reached. The transistor is in series with the magnet and I assume has opened, or, the integrated circuit that sends a switching voltage to the transistor is bad.
As soon as I locate my soldering iron I'll pull the transistor to test it.
If you're looking for a minor mechanical fix, this won't be it! I'm only trying to fix it because I'm bored, I doubt it will be cost-effective if I have to buy any parts.
Posted on Dec 28, 2010
mc1bean
  • 3053 Answers
SOURCE: need instruction manual for hamilton beach 2-slice
Hello, az
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
My breville toaster model BTA840XL won't drop the bread in for toasting
If your power-socket is off, it won't. (I've done it several times, foolishly cursing the toaster). :rolleyes:
Otherwise unplug from wall, remove covers, check by pressing base down with a pen etc. On most auto-eject toasters, a powerful electromagnetic solenoid (electric magnet) holds the base (slice carriage) down while cool and warming up. When preset temperature is reached, solenoid is de-energized, releasing its magnetic hold on the base, allowing springs to pop bread up.
If you (or friend) has a tester and expertise, check solenoid (small coil) for resistance. If OK, (not open circuit), problem is in control circuitry.
Dec 18, 2016 | Breville Kitchen Appliances - Others
For HB 22708 Toaster Oven: Will it toast both sides of a slice of bread at the same time?
Yes, the Toastation works like a traditional toaster in the top slots. If it is not toasting both sides like a regular toaster then there is a problem. If that is so and if it is still under warranty, then contact the company for repair. If it isn't under warranty, then find a local repair business.
Mar 29, 2011 | Hamilton Beach 22708 Toaster Oven with...
The bread only toasts on one side (each piece)
I take it it that the outside is being toasted and not the part between the slices? That would mean that the element that is shared by the two slices has burnt out. Check with a dealer for a replacement.
Jan 20, 2011 | Hamilton Beach Eclectrics 22111 / 22112 /...
Black & Decker Toaster, model 3550: Pressing the handle down to lower the bread and start the toasting doesn't lock in place anymore. The toaster will toast, but you have to hold the handle down so...
The fact that pressing down the lever fails, means the toaster contact will not function and can not be repaired. Since a two slice toaster is only $15 at Target, why bother fixing a toaster?
Feb 20, 2018 | Black & Decker Toast-It-All Plus T3550...
I have a H. Beach Type "T", Model # 22779 toaster that will not lock down for toasting.
Dec 24, 2010 | Hamilton Beach Kitchen Appliances - Others
Only toasts one side of toast
The cancel button is stuck in the in position
Jan 13, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Sep 27, 2008 | Hamilton Beach 22502 Digital 2-Slice...
Nov 05, 2007 | Hamilton Beach 22505 IntelliToast 2-Slice...
Hamilton Beach 22504 Toaster Logo
63 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
deton8 von Splosion
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
