Hi I have a NAD 5220 CD player and after starting a CD the sound becomes distorted after a short period of time . Any suggestions. Thanks
    New Friend:
U should try putting it at different levels if that doesn't work the buy a new one and sell the old one.
Posted on Nov 06, 2014
  • Hamish brown Nov 06, 2014
    Hi James . Not sure what you mean by different levels.
  • 158 Answers
SOURCE: Distorted sound when playing CD
have you tried cleaning the cd lens ?insert a lens cleaning cd , follow the voice instructions and your cd player will be as good as new.HAPPY LISTENING.
Posted on May 31, 2008
  • 99 Answers
SOURCE: NAD C541i CD Player plays but...
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Posted on Feb 02, 2009
SOURCE: NAD C541i CD Player won't turn on
I recently bought a second hand C541i as is and I had the same thing; no power up. I took it to a service centre, they re-soldered the connecting pins for the transformer socket. It now works well.
After that I realised that it could have been the problem with the Burson Audio clock that was installed buy the previous owner but had intermittent playback problems. A study of the schematic revealed that the +12v rail for the clock, is from a different secondary coil winding than the +5v for the DAC etc. And the -12v for the analogue output stage could be from a different pin on the connector as well.
I hope this helps.
Posted on Mar 03, 2009
  • 99 Answers
SOURCE: My NAD C251i CD player isn't reading disks - platform stops short
replace the loading tray drive belt.
it's under the tray, with the tray open you will be able to see a little plastic enclosure just at the front of the mechanism. clip this off and you will see the belt.
it is very common for this belt to lose tension and slip.
this is used for opening and closing the tray and raising the mechanism and engaging the disc ready for playback.
your problem is your belt slipping and not having enough tension to lift the mechanism all the way and that's why it stops short.
Posted on Sep 18, 2010
josema_sv
  • 512 Answers
SOURCE: NAD L40 stereo switches to
Maybe an FM amplified indoor antenna could help you to get a stable FM signal.
Posted on Feb 25, 2011
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Jan 04, 2010 | NAD C521 CD Player
My Sound occasionally crackles during use. There is also a screen lag at points when the sound begins to become distorted. Specifically when i move the cursor around, it will freeze for a short period,...
Hello sir/mam, as i analyze you problem, there are several points that may cause these problem, 1. your hard drive might have bad sectors that at a point the heads of the hard drive have difficulties reading the information thus cuasing the sound and lag of screen to become distorted. so i suggest you regularly scan for bad sectors. 2. its a long shot, it may be your software, you have to reinstall the porgram where you saw the lag. if every thing else fails, if its not a hassle, reinstall your OS and work with a fresh copy of programs on your laptop. if you have anymore questions, let me know. thanks
Jul 13, 2009 | Dell Inspiron E1505 Notebook
Nad cd player cd541i noise
Hi...
That one is going to need Tech service.
I've worked on several of the NAD players.
Sounds like a focus or gain adjust needed.
Feb 14, 2009 | NAD C521 CD Player
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Jan 27, 2009 | NAD T550 DVD Player
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
Nov 16, 2008 | NAD C541 CD Player
Car cd player problem
for "sat nav system is made by Becker 2003"
However, Their is 3 products in Becker
Car CD Changers (1)
In Dash Rec. (2)
Hope this helps
Nov 28, 2007 | Car Audio & Video
110 people viewed this question
 Grubhead
Grubhead
