I am trying to source a replacement IC chip. It is used as the control element in a switching power supply ckt. for a flat screen TV. Part numbers I have are QSCA0S0MS012 or Mip2f30msscf Dip7-a1. As t
I am trying to source a replacement IC chip. It is used as the control element in a switching power supply ckt. for a flat screen TV. Part numbers I have are QSCA0S0MS012 or Mip2f30msscf Dip7-a1. As the second P/N indicates, it is a dual inline package with 7 pins as opposed to the traditional 8 pin conf. I have not been able to find a source or to cross reference it to a compatible IC. Can someone please assist in finding where I can purchase one of these chips. Thank you, Don
    Novelist:
  • 167 Answers
This sounds like a proprietary part. Digikey doesn't have it. Contact the manufacturer of the TV.
Posted on Nov 06, 2014
2 Suggested Answers
  • 277 Answers
SOURCE: tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
Posted on Jul 21, 2010
Vizio lcd tv will not turn on but the
This is a very common issue with this model TV. The problem is caused by the power supply controller chip. This is a small 3 pin chip on the video logic board. When this chip fails the TV video board never gets the signal to turn on and display a picture. Here is a picture of the video controller board from the TV with the power supply controller chip circled, and here is a link to order the IC chip. Open the back of the TV and look at the little chip, you should be able to see that it is burnt. Replacing the chip should bring the TV back to life.
http://www.ccl-la.com/catalog/product_info.php?products_id=227
Jul 19, 2012 | Vizio L32 32 in. LCD HDTV
A straight line across the screen.
It looks like an IC has failed on your TV.
The IC is the vertical amplifier and needs to be replace to restore the functionality of your TV.
Apr 22, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Purchased a 32"Protron FLat Screen from SHOPNBC.com and the power light comes on but no picture; now it wont' come on at all.
Your partial resonance power supply IC chip with IGBT switch is bad. On your model of TV it will cheaper to replace the whole power supply module
Aug 20, 2010 | Protron PLTV-32 Television
Red status lite is on and tv doesnt come on at all
Your partial resonance power supply IC with IGBT switch is bad. Dont get afraid its just one IC chip with a long name. Have a tech check and replace it for you.
Aug 13, 2010 | Mitsubishi LT-46131 46 in. LCD Television
Tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Mar 17, 2010 | RCA L32WD22 32 in. LCD HDTV
LG 42lc2d found u502 in power supply blown up.
You won't find a part number for this ic. These boards were made to be replaced as one piece. A new board should do the trick. If you can try to check for a short to ground. Most of the plugs on the board have voltages labeled. If there is a dead short you will see it with an ohm meter.
Oct 14, 2009 | LG 42LC2D 42 in. LCD HDTV
Same problem with mine
Based on what you have described, you have lost the power supply or main board. Unplug unit, carefully lay it of the front side, pull about 10-20 screws out of the back, look at the electronic boards, if you know what caps are, run your finger across the top of the caps,if they are swelled up, then that board is bad. Those boards go for 150.00 to 500.00 each.
Sep 23, 2009 | Samsung LN-S4051D 40 in. LCD Television
Tuner problem
your problem is in the system control section of your tv. please check 1 supply to systemcontrol ic or loose contact. 2 supply or loose contact in tunning ckt of tuner (33v zener line) 3 aft ckt loose or defrctive. 4 loose button on remote &front panel of tv. 5 memory ic. 6 system contro ic. I think this will help. good luck . 4 system
Sep 28, 2007 | Sharp 32F640 32" TV
Tuner problem
your problem is in the system control section of your tv. please check 1 supply to systemcontrol ic or loose contact. 2 supply or loose contact in tunning ckt of tuner (33v zener line) 3 aft ckt loose or defrctive. 4 loose button on remote &front panel of tv. 5 memory ic. 6 system contro ic. 7 check for loose contact in tuner. I think this will help. good luck .
Sep 28, 2007 | Televison & Video
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
