Question about HANNA instruments : HI83099 - Bench Meter
How come i get incorrect readings with HI83099?
When i analyze for a parameter e.g nitrate using a sample with a known concentration, the instrument does not give the correct reading (the reading does not match the known concentration).
    Master:
  • 742 Answers
Recalibrate the tester..............
Posted on Nov 06, 2014
Does the 10,000 ppm limit apply to each sample that I use in a treatability study?
Yes, the limit applies to each individual sample that you use. No single sample may exceed a concentration of 10,000 ppm PCBs.
http://www.qjpcb.com/ Skype : wang.michelle35
Aug 15, 2016 | Smeg Repair Pcb / Module Dw1612 Dwi612c
Must I assume that a transformer has a PCB concentration of 500 ppm only if both the date of manufacture and the type of fluid are unknown?
Yes. You must characterize a natural gas pipeline system by analyzing
organic liquids collected at the condensate collection points (see §761.60(b)(5)(iii)). If there are no liquids present you must wipe sample in accordance with Subpart M, §761.250(a)(2). Select the proper sampling position along the pipe by following the directions in §761.247 (c) and (d). Then, according to §761.247(c)(3)(iii), if the entire population of pipe to be wipe sampled is porous and there are no non-porous surfaces available, assume that the pipe contains PCBs >50 ppm but <500 ppm and is PCB-Contaminated. Subsequently, an appropriate provision in §761.60(b)(5)(i) must be used to abandon the pipe. If you do not want to assume that the pipe is PCB-Contaminated, then you may apply for an alternate sampling plan under §761.61(c).
Jul 08, 2016 | Zanussi Repair PCB / Module for IZ12,...
I have DCA analyzer from Siemens healthcare and i have problem E24 ,How Can Solve it
Manual is available in PDF format from here
http://docslide.us/download/link/dca-operators-guide
http://docslide.us/download/document/?id=%2FJKJQj2KkZIjS9Tn4Jm5CAbRibVv%2BGl%2BT9wi7I03ZyGSjZf8c1bXQnPy2%2FSc3BFIu8t3mvccp4VXj23OQyX8pQ%3D%3D
DCA Vantage Operator's Guide 109
Troubleshooting
E22 - Optical
reading is out
of range
A Sample or Reference
channel reading taken
during an Air
measurement is too
high.
1. Discard the sample.
2. Run an optical test.
3. If you are unable to run an
optical test, contact your local
technical support provider.
E23 -
Excessive
noise on the
Sample
channel
The standard deviation
of the 16 readings at the
Sample channel for Dark
or Air reading is too
large.
E24 -
Excessive
noise on the
Reference
channel
Reference channel for
Dark, Air or Sample
reading is too large.
E26 -
Excessive
noise in sample
reading
Sample channel during a
reading taken is too
large in Sample read
position.
E27 -
Excessive
Lamp Drift
The change in mean
signal between
successive Air readings
is too large at either the
Sample channel or the
Reference channel.
E30 - Thermal
control system
error - low
The temperature
measured by one of the
cartridge holder
thermistors is ?2?C.
2. Restart the system.
3. If you are unable to perform a
successful restart, contact
your local technical support
provider.
E
Sep 21, 2015 | Siemens Dishwashers
What is a cholesterole analyzer?
A cholesterole analyzer is a machine that analyzes a sample of blood to check the level of cholesterole
Jan 08, 2014 | Health & Beauty
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
Numbers jump all over the place. Replaced battery. No change. Numbers continue to jump...never gives a weight.
I found that one of four feet of scales had the sensor short-circuiting. After padding it with two pencils so that it never gets pressed i get steady readings of right weight from three remaining (and no battery warning and rolling counter)
Oct 25, 2010 | Soehnle Slim F5 Scale 63721
How does music affect the human mind?
Music has a positive effect on the concentration level of the listeners. It is also found to improve one’s memory. Research has found that the silence between two musical notes triggers the brain cells and neurons, which are responsible for the development of sharp memory. Flute music, and instruments like santoor and sarod are recommended for the enhancement of concentration and memory. Strong beats cause the brain waves to resonate in synch with the beat bringing about higher levels of concentration and alertness.
Music plays a vital role in enhancing creativity. Music has a positive impact on the right side of the brain. Music triggers the brain center, which deal with the development of creativity. Certain ragas are known to activate all the chakras of the listener’s body, thus benefiting him/her in the performance of other creative tasks.
Music is found to give students the capacity to trust themselves. It provides them with an internal discipline. Rhythm is known to help the students learn math. Music stimulates the brain centers that deal with thinking, analyzing and planning, thus enhancing one’s organizational skills.
Music helps secrete endorphins that help in speeding the process of healing. It acts as an effective distraction from pain and suffering. While diverting one's mind away from pain, it also helps bring about certain chemical processes in the brain that aid healing. After undergoing surgery, patients may be advised to undergo a music therapy. Listening to melodious, comforting music is sure to have a positive effect on the physical and mental well-being of patients.
Apr 30, 2010 | Mustek Audio Players & Recorders
I have a stream of gases with known concentration and known flow rate to be capture in bottle of known volume. How can i have a guess calculations about the amount/volume of sample captured? khalil Ahmad
Your captured sample will be flow rate x time. Your bottle size is the upper limit of the amount you can capture (any more than that amount and the bottle will explode and you won't capture anything). You must allow for reduced flow rate as the pressure rises in the bottle.
Jun 29, 2009 | Wolfram Research Calculation Center
The parameter is incorrect
download a software called mini tone and it will read it
Feb 06, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Cannot open or copy - parameter is incorrect?
..wel, i solved mine.. im copying music files into a memory card like micro SD.. when im copying music.. it says.. cannot copy file.. the parameter is incorrect... then go into My Computer then Right Click the external hrd drive(micro SD),, then go to properties....then tools.. then click the Check now.. - it will check for some errors and automatically fix the errors.. :D thats it..
Oct 17, 2007 | Vivitar ViviCam 5385 Digital Camera
HANNA instruments : HI83099 - Bench Meter Logo
66 people viewed this question
Top HANNA instruments Science & Laboratory Experts
William McMath
Tom Chichester
Are you a HANNA instruments Science and Laboratory Expert? Answer questions, earn points and help others
