Question about Applica Black And Decker 12 Cup Programmable Drip Coffeemaker
<!-- from fixya rte -->Why does it leak water out of the bottom? - Applica Black And Decker 12 Cup Programmable Drip Coffeemaker
    Problem Solver:
  • 6 Answers
I own a Black & Decker (Applica) 12-cup Smartbrew Coffee Maker DCM2000 (see link). Mine started leaking water out of the bottom when brewing. I was able to remove the non-security screws and pry open the plastic bottom to see what the problem was.
Smart Brew 12 Cup Coffee Maker
In my case, the silicone hose running between the water reservoir and the heater/pump had become brittle over time and split where it met a metal tube.
There are two of these silicone tubes in the Smart Brew 12 Cup Coffee Maker DCM2000. In the third photo below, you can see the bottom/inside of the coffee maker with the faulty tube missing.
Replacing a silicone tube - easy. Getting the bottom completely open... not so much.
In order to get the bottom completely off, I used a bolt cutter on the security screw.
I was able to buy a length of the following hose (from ebay):
Silicone Tubing - High Temperature rated AND Food Grade
3/8" Inside diameter x 1/2" outer diameter
It's important to get the inside diameter correct, or the hose will not grip tight enough to stay in place/form a seal. I measured the original to get the appropriate I.D.
The hose must also 100% silicone, food grade, and rated for high temperatures. Beer stores and brewing supply companies typically carry this kind of hose. I got mine from ebay.
I cut the silicone hose to the proper length with a utility knife and slid it over the two receptacle ends - one end of the metal "U" & the round plastic socket leading into the water reservoir.
I put the bottom back on, attaching the regular Phillips screws.
I've had leak-free operation ever since.
The hose cost me a bit more than expected, because I couldn't get it locally and shipping costs in/to Canada are a complete rip-off - but it was still a fraction of the cost of a brand new coffee maker.
Why does it leak water out of the bottom? - leak-water-out-bottom-at5g3macwqtmzvkaw0snxryv-2-0.jpg leak-water-out-bottom-at5g3macwqtmzvkaw0snxryv-2-8.jpg
Posted on Jan 02, 2015
    Master:
  • 742 Answers
It is damaged, time for a new coffee maker
Posted on Nov 06, 2014
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
My bradford white 50 gallon hot water heater Model # M250S6DDs NCWW Serial # E610822231 D/N
Depends on source of leak: If gas water heater is leaking from bottom, then heater must be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-water-heater.html
Add a comment and describe type of water heater, and what you discover about source of leak.
May 25, 2013 | Water Heaters
WATER HEATER LEAKING
1) Copy following link for troubleshoot walk thru
2) Electric water heater might be leaking from element, and water appears at bottom of tank:
Feb 12, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Applica Black And Decker 12 Cup Programmable Drip Coffeemaker Logo
205 people viewed this question
Top Applica Coffee Makers & Espresso Machines Experts
ray gallant
Robert A. Watson
Robert A. Watson
chuchai
Are you an Applica Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
