Question about Dishwashers
<!-- from fixya rte -->I need electrical wiring bosCh sps 5432 - Dishwashers
Bosch sps/spi 64 dishwasher not starting cycle
Check if the pump impeller is free and not blocked with anything.TAKE GREAT CARE!! ISOLATE THE MACHINE BEFORE YOU DO THIS AND IT MY BE BLOCK WITH GLASS ETC!!!
There are u tube vids for this.
Oct 13, 2014 | Dishwashers
How should I wire a 4 channel amp for alpine sps 600, 609
they are only 4 ohm speakers so just put the front speakers on channels 1&2 or a&b and the rear on 3&4 or c&d since you are using a 4 channel amp thats what they are designed for
Jul 09, 2010 | Alpine SPS-600C Car Component System
Installing apline sps- 600c
use only one set of factory wires into the crossover. then from croosover to the alpine woofer and tweeter.
Feb 10, 2010 | Alpine SPS-600C Car Component System
I need to know the breaker size and wire gauge and number of wires needed for a bosch ae125 water heater
According to the user manual below, it's a 50 amp heater, therefore, you need 6 AWG electrical cable and a 50 amp double pole (220 volt) breaker in the main service panel.
You need two hot wires and a ground wire. The cable would be specified as 6/2 w/ ground. The 2 hot wires in the cable would be red & black or black & black -- these attach to L1 & L2 respectively. ( L = Line )
More info, let me know.
Charlie
http://ecx.images-amazon.com/images/I/A1b%2BxE2vITS.pdf
Oct 04, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Bosch dishwasher sps546 will not fill. switches on ok
you have to remove the cover of your unit in able to access the valve/.pump
Jul 08, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Im having trouble installing the sps-600c alpine speaker system. i need a wiring diagram or somthing as im un farmiliar with split speakers that dont have a cross over.
Hello lucal_s2000,
Well, actually those 600c's do have a crossover. It's encapsulated in the wiring you got with the components. Your head unit or amp speaker outputs connect directly to the woofers. The inline crossovers have a 12" wire on one end and a 22" wire on the other end. Connect the 22" side to the 2nd set of terminals on the woofers, and the 12" side to your tweeters, keeping all of the positives and negatives straight.
Here's an image of the connections.
5eca958.jpg Hope this helps.
Apr 12, 2009 | Alpine SPS-600C Car Component System
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
