Question about Sharp El-531x Scientific Calculator Green Bp Package Of 5
Showing a small p next to 0 and wont let me enter numbers 5-9
There's a small little o next to the number that I enter(10o)If I multiply by 2 it shows 12 ?
You configured the calculator to do calculation in base 8 (octal). Reset calculator or change numeration to base-10 (decimal).
May 07, 2012 | HP 35s Scientific Calculator
How to use RecZone password vault to change from alphabetical to numberical
on the reczone password vault you can enter numbers. on the button with 1@/.:, if you press the button once you will see @ entered. press the button 2 times quickly to enter a /. press the button 3 times quickly to enter a . press the button 4 times quickly to enter a :. press the button 5 times quickly to enter the number 1. press the next button 4 times quickly to enter a number 2. press the next button 4 times quickly to enter a number 3. press the next button 4 times quickly to enter a number 4. press the next button 4 times quickly to enter a number 5. bottom row: press the first button 4 times quickly to enter a number 6, the next button 5 times quickly to get a number 7, the enxt button 4 times quickly to get the number 8, the next button 5 times quickly to get the number 9, and the last button on the bottom row press it 4 times quickly to enter a number 0. pressing caps lock does NOT switch it from alpha to numeric mode. caps lock only gets the letters entered in UPPERCASE.
Nov 30, 2011 | Computers & Internet
I hasve a Uniden CEZ260 Corded Phone and i am trying to reprogram the numbers in the speed dial locations how do i do that.
To assign or change youe speed dial. Do the following: 1. Press STORE. LOCATION? shows in the display. 2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location. 3. Press STORE again to confirm the memory location. NOTE: Use Delete to erase existing memories or to correct errors. 4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. 5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The flashing cursor automatically moves to the next position
Apr 18, 2011 | Uniden CEZ260 Corded Phone
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
Feb 24, 2011 | NorStar T7316E Corded Phone
I have gotten and hdtv from a friend and when I turn tv on it says I need a pin number to enter. I can not get a hold of them to get pin. Is there anyway I can override this in the settings program?
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Dec 03, 2010 | Philips Televison & Video
How do I enter the number "0" when entering a password for WLAN? I'm trying to connect to a WLAN using WPA encryption with a password including the number "0" but when pressing "0" it shows up as a star...
Brother's documentation is non-intuitive. Pressing the ' 0 ' key shows a ' * ', but it actually is accepted as a 0 and moves to the next character entry position. Just take it on faith that it enters a 0 when it shows * when entering the wireless key.
May 28, 2010 | Brother MFC 7840W Printer
Can I make sony NS400D multizone and if not, what does it play...we got it secondhand..ngcosgrove@hotmail.com
on the rear of the player will be a region code plate with a picture of a globe and a number next to it.
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Mar 21, 2010 | Sony DVP-NS400D DVD Player
Office 2007 Product Key
From personal experience, could the Product Key be using;
Letter "O" or Number "0"
Letter "S: or Number "5"
Try switching the use of numbers for letters, that should correct your entering the required Product Key.
Feb 27, 2010 | Microsoft Office Professional 2007 Full...
How do you set the time and date?
Step 1.
Press the PROGRAM button, then press * * 1 2 3 4
The display should now read: USR-PGM NO?
Step 2.
Enter: 0 0 0
Display: Day/Time Set
Step 3.
Press NEXT (or the SPKR PHN button)
Display: shows date (if you need to change the date, see steps 5 thru. 10 below)
Step 4.
Press NEXT (or the SPKR PHN button) again
Display: shows time example: 12:00 AM
Step 5.
Enter the hour
to change current entry, press CLEAR (or the TRANSFER button)
Step 6.
Press --> (or FWD/DND button)
Step 7.
Enter the minutes
Step 8.
Step 9.
Press SEL (or AUTO ANSWER/MUTE button) to change AM or PM
Step 10.
Press STORE (or AUTO DIAL/STORE) - Don’t forget this step!
Step 11.
Press END (or HOLD button)
Step 12.
Press SPKR PHN button or pick up and hang up the phone to leave programming mode.
Dec 20, 2008 | Panasonic KX-T7731 Corded Phone
Forced cell entry
Select the cell(s), then click Data -> Validation. On the settings Tab, in Allow box choose List. In the Source box enter 0, 5. This will only allow these 2 numbers to be entered into the selected cell(s). There are many other validation combinations you can explore, this is the quickest way I found. Hope this helps.
Sep 11, 2007 | Microsoft Office Standard for PC
Sharp El-531x Scientific Calculator Green Bp Package Of 5 Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
