Question about Bosch Nexxt 800 Dryer
I have power to the display but dryer will not go on
Put a wet heavy comforter in the dryer. press the on button, and the dryer turned then smelt something burnt and dryer stopped. Is the motor fried or is there a overload button? Thanks Ronnie
    Master:
  • 742 Answers
More than likely you fried the belt or the motor.
Posted on Nov 06, 2014
Testimonial: "I have the back off and the belt looks fine, so it is the motor?"
  • Michael Carroll Nov 06, 2014
    Use a multimeter and check for voltage at the motor, if you get voltage but the motor does not turn then the motor is bad
  • Ron Steeves
    Ron Steeves Nov 06, 2014
    Thanks Mike I will try it.
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
How can I run diag on washer?
To place your wash machine into diag. mode..........
1. Press the (Delicates) + (Heavy Soil) buttons together at the same time for more than 3 seconds. Two zeros (00) should be dilsplayed in the display indicating that the washer is now in
(Service Mode). *Release both buttons when (00) appears.
2. Next press the (Presoak) button to put the washer into diagnostic mode.
3. Next press the down arrow button to retrieve the number code.
Note: There is a small paper that is tucked behind the control panel where it has all the wiring schematics, specifications and the code listings and the description of the number code. If your not comfortable to remove the panel to get to this paper, you can log on to (www.neptunehelp.com) and they should have a code reference chart for your application.
Sep 28, 2013 | Maytag Neptune MAH5500B Front Load Washer
Power button on GWL15 has issues
You will need to get a new tac switch installed into the display board
and put some clear packing tape over the crack on the decal to stop water getting in again and wetting the new switch.
Dec 06, 2012 | Fisher Paykel EcoSmart GWL15
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
My Fisher paykel dryer does not heat
Thermostat Cutout – Manual Reset (Electrical)
Type SPST 30 Amps/240 Volts AC
Trip Temperature 212°F (100°C)
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs
Conductivity Contact Impedance Check
To enter the conductivity contact impedance check, enter the diagnostic mode
as described above, then press the Auto Dry up button five times. In this
mode, touching damp clothes or fingers across the conductivity contacts will
cause the LED display to change. If the contacts, or the harness to them,
have gone open circuit, no change will occur in the LED display. This is a
useful method of checking the integrity of the sensor circuits.
To exit the diagnostic mode, press any cycle button.
Entering the Data Download Mode
button. This enters the diagnostic mode.
(c) Press the Regular button.
Encoded data is transmitted serially out the red Auto LED, and is be captured
by an optical download pen attached to a PC where “Smart Tool” software
interprets the data to aid servicing.
To exit, press the Regular button.
Entering the Showroom Mode
(b) Press and hold the Air Dry button, then press the Power button.
The LEDs will flash in a random sequence.
To exit, turn off the power supply to the dryer at the wall.
Tell me what sort of faults codes you can come up with and I will tell you what it means but in the meantime reset the limit and clean out the lint problem, open the stopped up vent. That dryer has to breath or that safety will kick out again. I have the manual
Sep 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Phone got wet...says download on the screen
Try turning ON the phone in recovery mode - Press and hold the volume UP and DOWN buttons while pressing the power button. It worked on my phone. Good luck!
Jun 06, 2009 | Samsung Propel A767 Cell Phone
I am trying to figure out the capacity on my Kitchen Aid dryer, model KEYS677EQ1.
dear customer the capacity for a dryer is mostly comen sense for example if you dry blankets they are farly heavy you can put as much as you like in your dryer but dont forget that wet cloth is heavy on your dryer or wet jeans it will work no problem but on the long run your dryer will wear out faster because of the weight normal clothe what goes in the washing machine goes in the dryer thankyou have a great day from gilles
Mar 15, 2009 | Dryers
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Bosch Nexxt 800 Dryer Logo
199 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
