Question about Music
<!-- from fixya rte -->Need schematic for hartke ha1400 - Music
2 Suggested Answers
  • 34743 Answers
SOURCE: I need a schematic diagram with values of components for a hartke gt100 amp
Request the schematic diagram directly from Hartke.
Posted on May 23, 2017
May 23, 2017 | Hartke Music
Dropped Hartke amp b 600 and now it has no sound
There are too many possible problems for someone to advise you without the amp on the bench. I suggest taking it to an authorized Behringer repair as they will have better access to parts should it be a cracked board.
Jun 06, 2016 | Hartke Music
Hartke vx115 lost significant volume
If you've tried different heads with the same result, the most likely problem is a blown speaker. Check it with an ohm meter, and if it's blown, you can either replace it or get it re-coned.
Apr 24, 2015 | Hartke VX115 - 1 x 15 Bass Guitar Cabinet...
Where can i find a hartke a70 schematic?
The schematic is here. http://music-electronics-forum.com/attachments/6771d1256866984-a70_sch.pdf
Jan 11, 2015 | Hartke A70 70 Watt Bass Amplifier Combo...
Hartke gt 100 no sound led and tube blinks
Perhaps it contains a fuse wich has been blown...or the transformer wich powers the speaker-cabinet
Nov 10, 2013 | Hartke GT100 Guitar Amplifier Head
Ha3500 hartke sound goes off with a click after 5 seconds .what is causing the problem
Sounds like the loudspeaker relay switch is disconnecting the spkr.
i) Check heat sensor on heatsink has good connection to PA board. Dust on h'sink/fan usually needs vacuuming off!
ii) Check voltage on the amplifier output resistor R334 is at 0v (referenced to chassis) - if this voltage is raised,the amp stage is faulty.
Otherwise the fault lies in the speaker protection stage (IC301).
Sep 24, 2013 | Hartke Ha2500 250watt Bass Amplifier Head
All three of my tone knobs are snapped off at the pots on my Hartke GT100 head. I wanted to know how I could find the right replacement pots, and how to install them myself.
Finding a parts list would probably require going to the manufacturer. The pots probably have a number on the side. The number is often the model number and the resistance value (encoded) and a letter signifying the "taper". You are probably better to contact Hartke and just order them from them to guarantee getting the right ones.
Sep 14, 2011 | Hartke GT100 Guitar Amplifier Head
My Hartke A100 has a problem, no power, the problem is transformer. what is the exact volt of transformer A100 hartke? than you
Transformers don't often fail. I have heard that some of these have a thermal fuse in them and they sometimes open. If you can get to the fuse in the windings, you can replace it and save the transformer. The fuses look like a silver tube about 5/8 inch long and 3/16 inch diameter with a lead out each end, They are marked with the temp they open and are a one-shot thing that have to be replaced.
May 30, 2011 | Hartke A100 Combo Bass Amp
Amps in a seires
I'm not sure what this will do, but electrically you can hook these up. Using the line output from the swx, connect it to the line level input. I think that that would be the active input. When you connect a guitar(without a battery powered pickup) to the hartke, it goes to the passive input right? If so, then connect the line out of the swx to the active input. Reverse if the behavior is opposite of what I described.
Realise that with these two connected to each other, you will be using both pre-amp sections and the amp section of the hartke.
Dan
Mar 01, 2010 | Music
Music Logo
53 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
