Question about Garden
Where can i find just the blower tube for WG508?
  • Garden Master
  • 14,411 Answers
Here's a link to get your tubes. Find Worx Parts Now
Posted on Nov 10, 2014
The heater blower stopped working and the fuse is not blown?
Blower Motor Removal & Installation W/O Air Conditioning Blower Motor (W/O Air Conditioning) gm-10-00-634.gif
To Remove:
  1. Remove the PCM.
  2. Remove the coolant reservoir.
  3. Remove the rear coolant recovery reservoir mounting stud.
  4. Disconnect the cooling tube from the blower motor.
  5. Disconnect the electrical connector from the blower motor.
  6. Remove the blower motor mounting bolts.
  7. Remove the blower motor insulating cover.
  8. Remove the blower motor.
To Install:
  1. Install the blower motor.
  2. Install the blower motor mounting bolts.
  3. Connect the electrical connector to the blower motor.
  4. Connect the cooling tube to the blower motor.
  5. Install the rear coolant recovery reservoir mounting stud.
  6. Install the coolant reservoir.
  7. Install the PCM.
W/ Air Conditioning Blower Motor (W/ Air Conditioning) gm-10-00-633.gif
To Remove:
  1. Remove the PCM.
  4. Disconnect the electrical connector from the blower motor.
  5. Move the PCM connectors out of the way.
  6. Remove the blower motor access cover screws. CAUTION
    Do not cut any deeper than necessary in order to remove the access cover.
  7. Cut through the access cover on the cut line using a sharp utility knife.
  8. Disconnect the cooling tube from the blower motor.
  9. Remove the blower motor mounting bolts.
  10. Remove the blower motor.
To Install:
  3. Connect the cooling tube to the blower motor.
  4. Install the blower motor access cover.
  5. Install the blower motor access cover retaining screws.
  6. Using black weather-strip adhesive, seal the cut line.
  7. Connect the blower motor electrical connector.
  8. Reposition the PCM connectors.
  9. Install the rear coolant recovery reservoir mounting stud.
  10. Install the coolant reservoir.
  11. Install the PCM.
Feb 08, 2011 | 1996 Chevrolet Blazer
Where do i switch theLEAF HOG FROM VACUUM TO BLOWER
Remove vaccuum tube. Allow the access door for the vacuum tube to shut all the way. Attatch the blower tube where you had the collection back for the vaccuum attatched. That is it.
Feb 01, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
How to replace main heater fan
Blower Motor REMOVAL & INSTALLATION Front Fig. 1: Front heater blower motor assembly 89696g02.gif
Remove the glove box to access the front blower motor, which is on the firewall 89696p02.jpg
The blower motor vent tube helps to cool the blower motor for efficient operation 89696p04.jpg
A ratchet with extensions makes removal of the retaining screws easier 89696p06.jpg
  1. Disconnect the negative battery cable.
  2. Open the glove box door. Gently squeeze the retainers at the rear of the box inward and allow the box to swing downward. NOTE: If additional access is required, unfasten the glove box hinge retainers and remove the assembly.
  3. Label and disconnect the electrical harness from the blower motor.
  4. Remove the blower motor housing tube and/or blower motor cover.
  5. Remove the blower motor retaining screws.
  6. Remove the blower motor from the A/C evaporator. To install:
  7. Install the blower motor in the A/C evaporator and tighten the retaining screws securely.
  8. Install the blower motor housing tube and/or blower motor cover.
  9. Connect the electrical harness to the blower motor.
  10. Reinstall the glove box and close its door.
  11. Connect the negative battery cable.
Rear Fig. 2: Service cover push pin locations 89696g03.gif
  2. Remove both rear passenger seats.
  3. Remove the three push pin retainers from the lower edge of the auxiliary heater and air conditioning service cover.
  4. Lift the service cover outward and upward to remove.
  5. Label and disconnect the electrical harness.
  6. Remove the blower motor housing tube.
  7. Loosen the three retaining screws and remove the blower motor. To install:
  8. Install the blower motor and tighten retaining screws securely.
  9. Install the blower motor housing tube.
  10. Connect the electrical harness.
  11. Position the service cover and install the three push pin retainers from the lower edge of the cover.
  12. Install both rear passenger seats.
  13. Connect the negative battery cable.
Dec 19, 2010 | 1998 Ford Windstar
Reconfiguring the blower to the vacuum
With unit unplugged, disconnect the blower tube. Open up the cover on the bottom of the machine. Insert the vacuum tube into the outlet at the bottom of the machine. Install the collection bag on the outlet of the machine where the blower tube goes.
Dec 12, 2010 | Craftsman 12amp Electric Blower with Vac...
How to change blowermotor on 2001 gmc jimmy
To Remove:
  1. Remove the PCM.
To Install:
  7. Install the PCM.
To Remove:
  1. Remove the PCM.
To Install:
Dec 08, 2010 | 2001 GMC Jimmy
Older leafhog don't know how to change over to blower instead of vacuum model Bv2500
Remove the vacuum tube completely from the bottom of the machine and make sure the impeller cover closes completely. Remove the collection bag off of the blower outlet. Now attatch the blower tube to that outlet on the blower. Done.
Dec 07, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
How do I convert from blower to vac
First, remove the blower tube. Then connect the collection bag on the blower tube outelt. Then open the bottom fan cover. Keep it open and connect the vacuum tube into the opening.
Dec 05, 2010 | Craftsman 225 Mph Electric Blower Vac
How do I change over from blower to vacum
Open the bottom vent where the air comes in...there should be a locking clip there that when depressed with a screw driver will allow it to open...Install the vacuum tube in the opening made by opening the vented bottom...then remove the plastic blower tube and install a collection bag on the outlet where the tube was.
Please vote on this solution.
Sep 11, 2010 | Black & Decker Leaf Hog Blower Bv4000
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
