I have a 65" lg plasma tv and I recently replaced s few capacitors that were bad and the tv worked beautifully, yesteddy morning I was watching and suddenly the tv went dim and fuzzy like snow but I still had colol and a fuzzy picture? This darkened fuzzy picture stays on all inputs, channels etc., so must be internal? Any advice?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
After replacement of the power board, Va&VS voltages are to be set according to the silk screen; can be located at the display panel, and it is a must for plasma displays.
Posted on Nov 06, 2014
  • 92 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
sounds like it may be a software upgrade
Posted on Oct 31, 2007
  • 15 Answers
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
  • 124 Answers
SOURCE: Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
Posted on Feb 21, 2009
  • 71 Answers
SOURCE: Sanyo Vizon 42' Plasma TV has lost its picture after 2 years
the bulb of your tv is dead. replace it
Posted on Mar 08, 2009
I have an LG 60PV400 plasma TV. While watching TV the screen goes black but the sound keeps playing. Sometimes the sound will just keep playing. Sometimes the TV while shut off.
Hi Joseph
Not sure what the LED codes will be. LG Tech support would know.
Is it under warranty still? If so, then get it to a service centre.
If not, Then you might want to check for leaky Electrolitic Capacitors.
This is the biggest ploblem with modern Digital (computer) Flat Panel TV's
Might be a little early to spot the "Bulging" or leaking until it gets worse.
If your up to it & you can spot the bad caps & unsolder & replace for a few bucks.
Good Luck
Switched mode power supply
How to Replace an Electrolytic Capacitor
Take Static Discharge Precautions inside devices
Antistatic wrist strap
Feb 13, 2016 | LG Televison & Video
My lg plasma sound ok picture not clear and red
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG Televison & Video
LG 32LC2DB television says No Signal after 30 min
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | LG Televison & Video
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
Jun 10, 2011 | LG 42PX8DC Plasma TV
TV LG Model 50PX1D-UC Flat Panel Television Loud Popping Noise. TV goes out. I turned on my tv the other morning and it let out a loud popping noise and the picture went out. Any suggestions...
The problem is that there is a bad capacitor inside the unit, it is either on the main panel or the power panel. The popping sound you got was due to the fact that the lead on the capacitor was bridging, therefore causing some electrical popping sound.
Run a check on the main panel and the power panel for any bad capacitor and replace it with a new one. That way, your television will be in good condition once again.
Take care and good luck
Jan 02, 2011 | LG 50PX1D 50 in. Plasma Television
I have an LG 42PC1DA. We were watching TV and it popped- the picture went but there is still sound. I have read through a few different posts on here and they have conflicting advice. I don't want...
A popping sound is a clear indication that one of the electrolytic capacitors has failed the big way. You were lucky it didn't fried anything else. Just open the tv find and replace the failed capacitor. Soldering is required so if you haven't done this before then its time to call someone who has.
Aug 05, 2010 | LG 42PC1DA 42 in. Plasma HDTV
LG Plasma TV automatic turn off right after turn on
You have some dried out capacitors on the power supply. Samsung has a major issue with this right now and I made a tutorial for that repair in my Tips & Tricks. Your capacitors will not be the same, but identifying them and replacing them will be. Best advise I can give you: Stop using the TV and unplug it until you get it fixed. When these caps go bad, they draw down the voltage they are filtering. I've seen some TVs that had secondary damage because of this. I hope this was of some assistance, best wishes.
Apr 19, 2010 | LG 42PX4DR 42 in. Plasma TV
Lg 42inch plasma tv clicks several times before turning on. Then it works fine until you turn it off and back on again. Then the same thing happens. This has just started to happen in last 2 weeks. Any...
You have bad capacitors on the Power Supply PCB. There's probably like 9 of them bad, if memory serves me correctly. I have a tutorial published on a Samsung repair involving capacitors. It's not identical, but the solution is similar. I think in the case of your TV, you'll be looking for 3300uF caps with swollen tops. If after looking over the tutorial you decide this isn't for you, get the TV to a repair shop. I highly recommend you stop watching it and unplug it until you get this fixed. I hope this was of some assistance.
Apr 13, 2010 | LG 42PX5D 42 in. Plasma HDTV
My tv shut off while watching it and now it won't power on
your power supply probaly failed. you will need to remove it and look for blown capacitors or leaking ones. replace the bad parts
Jan 03, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
