Installed hub on Tuesday want to know if broadband shield is turned on
How can I check if broadband shield is on
    Master:
  • 742 Answers
Access settings menu and check it
Posted on Nov 06, 2014
Want to know if broadband shield turned on router?
It is not turned on in your router, it is part of the service filtering provided by Sky's broadband service.
Instructions on how to turn it on and off are on sky's website, here.
Sky Broadband Shield explained
Nov 06, 2014 | Computers & Internet
How do I know if broadband shield is turned on
Access the administration pages and look at the security services.
How do i replace rear wheel bearings
Remove tire, brake caliper, rotor, and abs sensor. Remove complete steering knuckle with hub, rotor sensor, splash shield, and bearing with seals from tie rod, strut, and ball joint. Take complete steering knuckle with hub, rotor sensor, splash shield, and bearing with seals to auto machine shop to have old bearing and seals, and rotor sensor with hub pressed out and new bearing and seals, and rotor sensor with hub pressed in. Don't forget the splash shield that fits between the the steering knuckle and rotor sensor with hub. Reassemble in reverse order. Pay special attention to abs wheel speed sensor specifications. Any further help: innovatactive@yahoo.com.
Mar 16, 2013 | 1994 Mitsubishi 3000GT
How do i speed up my wifi?
There're a number of ways to "broaden" your Broadband Wi-Fi link.
(a) move laptop closer to the Wireless Router, and/or remove signal obstructions between laptop and Wireless Router.
(b) move the Wireless Router to a channel other than the default (channel 6).
HOW: login to the Router management pages at 192.168.1.1, and change it.
(c) upgrade your Wireless-G router to Wireless-N (with the Linksys WRT310N you've aready done that, however).
(d) Switch from Wi-Fi to hardwired with a Cat 5e ethernet cable - you'll have better throughput and fewer CRC errors with a hardwired link.
(e) Recognize that 99% of the time the upload/download speed bottleneck is not the Broadband link, but the computer laptop system itself, so the best way to increase the speed of your Wi-Fi link is to optimize the computer system. Normally, increasing the physical link speed is wasted time and money - something those Verizon FIOS commercials will never tell you.
Put your money into upgrading RAM and running fewer startup group processes eating into system virtual memory (SWAPFILE.SYS) space.
If you can access only trusted web sites (typical of a workplace workstation), then you can optimize browser operation by eliminating Real-Time Anti-Virus shields such as: (File System Shield) scan on open, (File System Shield) scan on write, HTTP shield, Network shield, suspicious behavoir shield, Script Shield, and IM Shield. This will help to optimize your browser's activities. Web browser software is well known to be among the least efficient software ever devised. The typical user will have half a dozen Browser Extensions, and a dozen or more Browser Plug-ins, each further burdening an already over-burdened Browser. Most Users don't even know how many Browser Extensions and Plug-ins they're running, and inadvertently permit new ones to be installed daily.
Consider upgrading your laptop's CPU, rolling back from Windows 7 to Windows XP, and changing Operating Systems from a Microsoft Windows OS to Linux. Also consider using an Apple MacBook.
Lastly, perform a security scan on your system - nothing wrecks a laptop's performance faster than a virus/worm/trojan horse/rootkit/malware/spyware/tracking cookies/supercookies, etc.
Dec 04, 2011 | Linksys WRT310N Wireless Router
On my hub right, on broadband it's shows that it's red meaning that it's not working properly. can you tell me what's the problem please
Power-off the hub.
Power-on the hub.
Did the problem go away?
Call your Internet Service Provider, to check if they are supplying a broadband connection "into" your hub. If they are not, then they need to fix a problem at their end.
May 28, 2010 | Network Computing Devices (NSH800S/A)...
NH1005
connect your broadband modem into hub. configure your broadband modem to PPPOE. then u can access internet in both pcs.
Mar 10, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
I have installed BT home hub broadband and since then Macromedia wll not open. Error message 'entry point not found macromedia.exe. It then says tries to open and gives an error message 'The procedure...
that sounds more like a permissions issue, with your settings on your isp/browser...
when changing ISP's it's sometimes necessary to 'train' that interface for your usual work places.
check your computers warranty here 4 FREE
Feb 29, 2008 | Computers & Internet
Not making a connection to broadband router
Hi, If I understand you right, you installed a hub after your router, all your PCS are connected to the hub and it is working. Then you should not be concerned, first, you did right, second, as long as it works and isn't slow or disconnecting then no issues. A few buts: 1. If your router has 4 ports, then you don't need the CP3008a and 2. why only "2 lights on cp3008a" if you have 2 PCS + the router, you should have 3 lights; At the end of the day,if it works and you have no complain, let it be. Kind regards.
Aug 24, 2007 | Accton Refurbished CHEETAHHUB POWER-3008A...
Wireless hub
No, you do not have to have the broadband software installed. To access the MS base station go to : http://192.168.2.1/login.htm Using it as a hub and access point requires you to configure is as such. The MN700 can act as a hub/wireless access point using an ethernet cable from your router to the modem port on the base station. The base station has to be setup with the ethernet cable in port 1 on the base station connected to your PC. see "Reconfigure the MN-500 as a Wireless Bridge" in this article. same steps apply for your MN700 http://www.fixya.com/ThreadView.aspx?thid=102065&prdid=254958 The last step is to reconnect the ethernet cable from the router to the modem port on the MN700.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
