How do I know if broadband shield is turned on
Installed hub on Tuesday want to make sure broadband shield is turned on
    Master:
  • 623 Answers
Access the administration pages and look at the security services.
Posted on Nov 07, 2014
Want to know if broadband shield turned on router?
It is not turned on in your router, it is part of the service filtering provided by Sky's broadband service.
Instructions on how to turn it on and off are on sky's website, here.
Sky Broadband Shield explained
Nov 06, 2014 | Computers & Internet
How do i replace rear wheel bearings
Remove tire, brake caliper, rotor, and abs sensor. Remove complete steering knuckle with hub, rotor sensor, splash shield, and bearing with seals from tie rod, strut, and ball joint. Take complete steering knuckle with hub, rotor sensor, splash shield, and bearing with seals to auto machine shop to have old bearing and seals, and rotor sensor with hub pressed out and new bearing and seals, and rotor sensor with hub pressed in. Don't forget the splash shield that fits between the the steering knuckle and rotor sensor with hub. Reassemble in reverse order. Pay special attention to abs wheel speed sensor specifications. Any further help: innovatactive@yahoo.com.
Mar 16, 2013 | 1994 Mitsubishi 3000GT
How do i speed up my wifi?
There're a number of ways to "broaden" your Broadband Wi-Fi link.
(a) move laptop closer to the Wireless Router, and/or remove signal obstructions between laptop and Wireless Router.
(b) move the Wireless Router to a channel other than the default (channel 6).
HOW: login to the Router management pages at 192.168.1.1, and change it.
(c) upgrade your Wireless-G router to Wireless-N (with the Linksys WRT310N you've aready done that, however).
(d) Switch from Wi-Fi to hardwired with a Cat 5e ethernet cable - you'll have better throughput and fewer CRC errors with a hardwired link.
(e) Recognize that 99% of the time the upload/download speed bottleneck is not the Broadband link, but the computer laptop system itself, so the best way to increase the speed of your Wi-Fi link is to optimize the computer system. Normally, increasing the physical link speed is wasted time and money - something those Verizon FIOS commercials will never tell you.
Put your money into upgrading RAM and running fewer startup group processes eating into system virtual memory (SWAPFILE.SYS) space.
If you can access only trusted web sites (typical of a workplace workstation), then you can optimize browser operation by eliminating Real-Time Anti-Virus shields such as: (File System Shield) scan on open, (File System Shield) scan on write, HTTP shield, Network shield, suspicious behavoir shield, Script Shield, and IM Shield. This will help to optimize your browser's activities. Web browser software is well known to be among the least efficient software ever devised. The typical user will have half a dozen Browser Extensions, and a dozen or more Browser Plug-ins, each further burdening an already over-burdened Browser. Most Users don't even know how many Browser Extensions and Plug-ins they're running, and inadvertently permit new ones to be installed daily.
Consider upgrading your laptop's CPU, rolling back from Windows 7 to Windows XP, and changing Operating Systems from a Microsoft Windows OS to Linux. Also consider using an Apple MacBook.
Lastly, perform a security scan on your system - nothing wrecks a laptop's performance faster than a virus/worm/trojan horse/rootkit/malware/spyware/tracking cookies/supercookies, etc.
Dec 04, 2011 | Linksys WRT310N Wireless Router
How do i pull the hub off my 2002 mazda , on drivers side front
REMOVAL & INSTALLATION Except Miata FRONT
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Steering knuckle from the vehicle
    • Inner oil seal from the knuckle
  3. Using Mazda Hub Puller tools 49 G033 102, 49 G033 104 and 49 G033 105, pull the front wheel hub from the knuckle assembly.
  4. Remove or disconnect the following:
    • Bearing inner race from the front wheel hub
    • Retaining ring from within the knuckle
    • Front wheel bearing from the knuckle, using the hub puller tools
    • Brake dust shield
  5. Clean and inspect all parts but do not wash or clean the wheel bearing. The bearing must be replaced. To install:
  6. Using Mazda Press tools 49 G033 107 and 49 H026 103, install a new dust shield cover assembly to the knuckle.
  7. Using the press tools, press a new wheel bearing into the knuckle assembly.
  8. Install or connect the following:
    • Wheel bearing retaining ring
    • New oil seal using Installation tool 49 V001 795
    • Front wheel hub using the Mazda press tools
REAR
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section. NOTE: The wheel bearings are not serviceable. If the bearings are bad, a new hub/bearing assembly must be installed.
    • Rear wheels Fig. 1: Exploded view of the rear wheel hub and bearing assembly (disc brake model shown, drum is similar) 7923mg87.gif
    • Brake drum, if equipped
    • Rear caliper and rotor assembly from the hub, if equipped
    • Hub dust cover
  3. Raise the staked portion of the hub retaining nut with a hammer and chisel.
    • Hub retaining nut and discard it
    • Hub and bearing assembly from the spindle Fig. 2: When installing the new hub nut, be sure to stake it into the notch on the spindle 7923mg86.gif
    To install:
  5. Install or connect the following:
    • Bearing assembly on the spindle. Torque the new nut to 131-173 ft. lbs. (177-235 Nm)
    • Stake the nut into the groove in the spindle
    • Dust cover
    • Assemble the brakes
    • Rear wheel
Jan 01, 2011 | 2002 Mazda Protege
On my hub right, on broadband it's shows that it's red meaning that it's not working properly. can you tell me what's the problem please
Power-off the hub.
Power-on the hub.
Did the problem go away?
Call your Internet Service Provider, to check if they are supplying a broadband connection "into" your hub. If they are not, then they need to fix a problem at their end.
May 28, 2010 | Network Computing Devices (NSH800S/A)...
Replace front right wheel bearing assembly on a 2001 ford taurus
please rate as solved if this helps
SECTION 204-01: Front Suspension 2001 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub
Material Item Specification Rust Penetrant and Inhibitor
F2AZ-19A501-A ESR-M99C56-A High Temperature Nickel Anti-Seize Lubricant
F6AZ-9L494-AA ESE-M12A4-A
Removal and Installation
s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Suspension fasteners are critical parts because they affect performance of vital components and systems and their failure can result in major service expense. A new part with the same part number must be installed if installation is necessary. Do not use a new part of lesser quality or substitute design. Torque values must be used as specified during reassembly to make sure of correct retention of these parts.
  1. Remove the wheel knuckle (3K185). For additional information, refer to Wheel Knuckle in this section.
Wheel Knuckle
Special Tool(s) s1h~us~en~file=st1516a.gif~gen~ref.gif Remover/Installer, Front Wheel Hub
204-069 (T81P-1104-C) s1h~us~en~file=st1517a.gif~gen~ref.gif Adapter, Wheel Hub
205-237 (T86P-1104-A1) s1h~us~en~file=st1515a.gif~gen~ref.gif Installer, Halfshaft
204-067 (T81P-1104-A) s1h~us~en~file=st1518a.gif~gen~ref.gif Remover, Wheel Stud (Metric)
204-085 (T83P-1104-BH1) s1h~us~en~file=st1263a.gif~gen~ref.gif Remover, Steering Arm
211-003 (T64P-3590-F) s1h~us~en~file=st2461a.gif~gen~ref.gif Adapter for 211-S200
211–211 (T96P-3010–A1) s1h~us~en~file=st1106a.gif~gen~ref.gif Remover, Tie-Rod End
211–001 (TOOL-3290–D) or equivalent
Removal
s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Suspension fasteners are critical parts because they affect performance of vital components and systems and their failure can result in major service expense. A new part with the same part number must be used if installation is necessary. Do not use a new part of lesser quality or substitute design. Torque values must be used as specified during reassembly to make sure of correct retention of these parts.
All vehicles
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Discard the wheel hub retainer (3B477). It is a torque prevailing design and cannot be reused. If loosened, the retainer must be removed and a new one installed.
    NOTE: Make sure the steering wheel is in the unlocked position.
    Remove the hub cap or wheel cover, the wheel hub retainer, and the washer. Discard the retainer.
  1. Remove the front brake disc. For additional information, refer to Section 206-03 .
  1. Remove and discard the cotter pin and nut.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the tie-rod end boot when installing the special tool.
    NOTE: Remove the adapter from the ball end of the special tool. Apply a small amount of grease to the tie-rod end stud and the ball of the special tool.
    Using the special tools, disconnect the tie-rod end.
Vehicles equipped with ABS
  1. Remove the bolt and detach the ABS sensor.
  1. Unclip the ABS sensor wire retainer and position the sensor out of the way.
All vehicles
  1. Remove and discard the nut.
  1. Using the special tools, disconnect the ball joint from the lower arm.
  1. Using a pry bar, push the lower arm down until the ball joint is free of the arm.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not allow the halfshaft to move outboard. Over-extension of the tripod CV joint can result in separation of internal parts, causing failure of the halfshaft.
    NOTE: Hold the threaded rod while turning the nut.
    Using the special tools, press the halfshaft from the wheel bearing and hub. Wire the halfshaft in a level position.
  1. Remove the flag bolt and the knuckle.
  1. If necessary, remove the wheel hub and bearing. For additional information, refer to Wheel Bearing and Hub in this section.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care not to damage the knuckle or dust shield when drilling out the rivets.
    If necessary, remove the dust shield.
    1. Using a 5.5 mm (0.22 in) drill bit, drill out the rivets. If a larger bit is needed, do not use a bit larger than 6 mm (0.24 in).
    1. Remove the dust shield.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The wheel bearing and hub is not pressed into the knuckle. Do not use a slide hammer or strike the inner race of the bearing. Damage to the bearing can result.
    NOTE: If necessary, lubricate the knuckle and bearing with rust inhibitor meeting Ford specification.
    Remove the bolts and the wheel hub and bearing (1104). Discard the bolts.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The knuckle bore must be clean enough to allow the wheel bearing and hub to seat completely by hand. Do not press or draw the wheel hub and bearing into place.
    Clean and inspect the knuckle bearing bore. If the knuckle is cracked, install a new knuckle.
  1. Lubricate the knuckle bearing bore with anti-seize lubricant meeting Ford specification.
  1. To install, reverse the removal procedure.
May 16, 2009 | 2001 Ford Taurus
NH1005
connect your broadband modem into hub. configure your broadband modem to PPPOE. then u can access internet in both pcs.
Mar 10, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
TOSHIBA
Asuming you are knowledgable about hooking up broadband i will guess that you know for a fact the its a good connection on the broadband routers side and there is actuall internet access and the problem is with your laptop.
If so then make sure you have the right installs.
get into your start menu at the bottom left> hover over settings>click on network connections and wait for the window to open. Right click on " LOCAL AREA CONNECTION" and select properties.
The little box should open showing a scrollable menu and say " Local area connection Properties" at the top. Make sure in the list of installed Items, you have at least the TCP/IP internet protocal installed and add version 6.
Also you can try cycling the power to your internet broadband router. Hook up the laptop, turn it on and log in, If you have a router that you are using to branch off your broadband to several computers, then unplug, wait 30 seconds and polug back in and it should register. If you are plugging directly into the Broadband router, cycle the power on it the same way.
Also make sure you are plugged into the right port on the router:)
Hope this helps.
Feb 15, 2008 | Computers & Internet
Wireless hub
No, you do not have to have the broadband software installed. To access the MS base station go to : http://192.168.2.1/login.htm Using it as a hub and access point requires you to configure is as such. The MN700 can act as a hub/wireless access point using an ethernet cable from your router to the modem port on the base station. The base station has to be setup with the ethernet cable in port 1 on the base station connected to your PC. see "Reconfigure the MN-500 as a Wireless Bridge" in this article. same steps apply for your MN700 http://www.fixya.com/ThreadView.aspx?thid=102065&prdid=254958 The last step is to reconnect the ethernet cable from the router to the modem port on the MN700.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
