Question about Water Heaters
How do i replace the element on a Cointra TE 80 Hot Water Tank
The element i believe keep stripping the main fuse board - after doing a continuity test the issue seems to be the element and i need to replace it How can i do this from beginning to end..??
  • Water Heaters Master
  • 5,089 Answers
  • 653 Answers
SOURCE: Hot Water Heater runs too hot
Here is the website for ThermoDisc. It looks like the 59T thermostat is still available. http://www.thermodisc.com/productdetail.asp?ProductID=84. On a positive note, the PT valve (pressure/temperature relief valve) is supposed to pop off before the tank blows up. An electric water heater rarely lasts more than about 11 years under good conditions, so I think it would be wise to weigh the possibility of replacing the water heater. Newer ones have much better insulation which should save you in operating costs over the long run. In addition, if you fix it now, then something else goes bad, and it will, you will probably conclude replacement would have been the better option.
Posted on Mar 16, 2009
rick_stokes_
  • 61 Answers
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Posted on Sep 19, 2009
heatman101
  • 43501 Answers
SOURCE: GE Smart Water Heater Model# GE50M6A. Hot water
Your bottom element is burned out. You will still get hot water from the top one, but like you said, not nearly as much.
Do a search for "appliance parts" and then enter your model number and you will be able to purchase the aprt online. Check a number of different sites as the prices can vary greatly. Many of these sites will have exploded views, so that you can see how they come apart and go back together. Wire the new element in exactly as you remove the old one. The bottom one will only have two wires so it is very easy.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 30, 2009
  • 105 Answers
SOURCE: reset button keeps tripping, water gets too hot
replace the thermostats, be very careful!!!! thats 220volts for elec water heaters, 220volts kills you if you touch it wrong,.....it is one thermostat but it's best to match them, so you'll need both,...not expensive. good luck, cracklin joe
Posted on Jan 08, 2010
Testimonial: "Thank you. Replacing both thermostats solved the problem. The heater is working well."
SOURCE: Currently have leaking expansion tank and have
HI sorry its shot, they go every now &then.You can run it like you say temporary BUT the boiler needs low pressure to force heat @10 or 12 p.s.i. This pressure will leak out of the hole and you eventaully loose heat & get noise.If you got a pinhole leak in tank.With the main off.Slow it down with duct tape or a rag if you can and leave water on.
Posted on Mar 30, 2010
Testimonial: "thanks. we changed it out this morning all is good."
I have a Bosch Powerstar Ae115 and the left cutout keeps tripping. It has worked great for 5 years. When i reset it, the water gets warm again(never hot as it was before). What could be causing it to trip?
Water leaking into elements. Bad PC board. Undersized breakers. Undersized main panel.
Bosch Powerstar is a computer that happens to heat water.
If your 5-year-old laptop computer was malfunctioning, you would not be surprised.
But for some reason (false marketing by manufacturers?), folks believe a tankless computer is going to last 20 years.
Moreover folks also believe tankless will provide endless hot water while saving money.
The whole idea of tankless saving money is a load of sales-BS that defies physics and common sense.
There are no service manuals... except bosch website has troubleshoot section in product manual.
Call a bosch-qualified service tech.
Go to Lowes and buy ordinary tank heater, and fix your heater today for only $250.
Tank-type electric water heater can be easily repaired and maintained by homeowner to last forever... that is a fact
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Gene
Jan 12, 2014 | Water Heaters
My suburban dsi rv hot water keeps throwing breakers
Appears to be a short in tank circuit probably cause by a water leak in tank. These usually wear a rusty hole in the tank inside the cover and are not seen unless the thermostat covers are taken off. I would remove them and do a visual thoroughly. Anytime a fuse blows or a breaker trips is always a dead short unless you have a bad breaker. I would check those as well for vibrating, chattering noises, and/or smoking. If any of this persist, replace breaker. A melted heat element could trip them, but not usually for it leaves an open circuit instead of a shorted one.
Feb 19, 2013 | Suburban SW10DEM Gas Electric Water Heater...
My hot water heater is 6 yrs old should i change the elements or replace the water heater
Replace elements and thermostats
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Check the anode rod
http://waterheatertimer.org/Replace-anode-rod.html
If anode is replaced, then tank will not rust.
This maintenance will keep electric water heater is good operating order indefinitely.
You never need to replace electric water heater if water pressure is kept below 80 psi, and anode is good and keeps tank from rusting.
Nov 20, 2012 | Water Heaters
Water heater supplies about a pint of hot water than turns cold?? what is th eproblem
Hello Rsjohnson164,
I understand that you are having a problem with your hot-water tank not producing any amount of hot-water. I would suggest that you turn off the cold water supply to your hot water tank and drain the tank and see how much water comes out of it.
Flush the tank:
1. Turn off the cold water supply
2. Hook a water hose to the boiler valve (spicket on the bottom of the tank) and turn on the valve
3. Turn on the cold water inlet line and let it run for about 15 minutes or until you get good pressure coming out.
Check the Elements:
1. Turn off the power to the hot-water tank
2. Remove the service panels
3. Remove one wire from the element and use a multi-meter to check continuity
4. If no continuity replace one or both elements
If you do all of this and still have a problem repost to this thread and we will check your thermostats to make sure they are working properly.
Thank you for choosing FIxYa.com
Justin
Apr 21, 2011 | RELIANCE ELECTRIC WATER HEATER
I replaced all parts but water heated won't get hot
You have electric water heater.
You replaced elements and thermostats but heater still won't work.
And tank was completely full of water, and water was running out of a faucet before turning power ON.
If elements are not fully immersed in water, they will instantly burn out.
If upper element is burned out, then tank will have NO hot water.
If lower element is burned out, and upper element is not burned out, then tank will have some hot water.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-it-works.html
If elements did not burn out, then that leaves 1 main suspect: the electricity.
1) Push in ECO red reset button on upper thermostat. If ECO is tripped out, then heater will not work.
2) Click circuit breaker all the way one direction and then back the other direction to make sure breaker is latched.
3) If tank has 2 elements, then it is 240volt.
If 1 leg of 240Volt circuit is not working, then 240V appliance will not work.
240Volt circuit needs both hot wires to complete the circuit:
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#120-240
Buy cheap multimeter from Home Center and set dial to 240-250-277VAC
Tape tester leads to woods sticks to keep hands away from power.
Power is ON
Test across top 2 screws on upper element should show 220-240 volts.
If you have 240 at top two screws, then skip down to step 6.
If no reading across top two screws, then move to top of tank.
4) Open connection point where wire connects to heater.
Test across both insulated wires should get reading of 220-240 volts.
If no reading, move to circuit breaker box.
5) Mark water heater breaker.
Turn off all breakers except water heater breaker and main breaker. (and breaker to light fixture where box is located)
Do not hold or touch or lean against anything metal.
Stand on dry boards and wear dry clothes.
If main breaker is OFF, the big wires that connect to main breaker are still HOT.
Remove box cover.
240Volt breaker has 2 wires connected with screws.
Test across both screws for 240Volt.
See if wires are loose.
If there is no reading, then breaker is not working on one leg.
To double check, move water heater wires to another same-size 240V breaker and then put ear against water heater to listen for bubbly-fizzing sound.
6) If you are getting 240 to water heater, then wire inside tank could be loose.
Do 30 minute troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 09, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem Model # 82V52-2 and its being supplied by 25 amp breakers. They do not trip out but the 100 amp main gets real hot and trips out and I believe it happens when the water heater is in use- any...
The Rheem water heater uses 4500 Watt elements
Check label on side of any appliance to see electrical rating details
2 element tank with two 4500 watt elements is still a 4500 watt appliance since both elements are never ON at same time.
Volts x amps = watts
amps = watts divided by volts
amps = 4500 divided by 240Volts or 220Volts
amps = 18.75
Your water heater uses 18.75 amps to 20.45 amps
Your 25 amp breaker should only carry 80% of rated value
25 amps x 80% = 20 amps.
So your water heater breaker is correctly sized.
You should have a 10 gauge wire going to this water heater.
12 gauge wire is a bit undersized for 4500 Watt water heater
Feel the water heater wire to see if it is warm.
If the main breaker is getting hot when 20 additional amps are being used by the water heater.
1) The house is using more amps than your 100 amp main can carry
Using the formula, 100 amps x 80% = 80 amps for the main breaker
Add up your total amp draw.
For example if your 3500 watt oven is ON, it draws 16 amps.
If your 5000 Watt electric heater is on, it draws 23 amps.
Your 1500 Watt 120V microwave draws 12.5 amps.
Add these numbers up plus your water heater, and it comes to 71 amps.
71 amps is getting close to the max 80 amp, but it's not over.
Now if you have a pool pump and and hot tub and a table saw going, the main breaker could be overdrawn.
2) To solve the problem short-term, you can put a timer on the water heater and use it only when needed.
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
3) The main breaker is bad and needs to be replaced.
If you need help figuring circuits or timers, add a comment and I will help
Nov 05, 2010 | Rheem Water Heaters
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The water gets too hot and trips the reset on the thermostat.
Two possibilities. 1 failed upper or lower Tstat 2 Shorted element
To test element: disconnect both wires to element terminals. use continuity tester to see if there is continuity through element (one probe on each element terminal) If no continuity element is bad. Then test for continuity between each element terminal and the water heater itself.( one probe on element terminal and one probe grounded on bare metal or inner tank.) If there is continuity from terminal to ground, element is bad and also can cause tank to continue heating even when thermostat shuts off. This is because the thermostat only shuts off one pole of the 220 and a shorted element can continue heating from the 2nd pole.
If both elements test OK and water heater heats the full tank( tank feels hot at bottom element access panel when no hot water for 2 hours) most likely the lower thermostat is bad.
Jan 25, 2010 | Reliance Water Heater #6-30-DORT 30GAL...
Warm water only
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heating elements do not operate together
That's how they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank
Mar 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
105 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
