Question about Music
My ct 470 works with batteries but not with the power supply adaptor. I bought a new adaptor but it still doesn't work. Is they anything I can do?
Its been in the loft for years but appears to work fine with batteries but nothing at all when plugged into the mains.
    Master:
  • 742 Answers
Bad power Jack...................
Posted on Nov 06, 2014
Testimonial: "Thanks for the suggestion but I have tried 2 adaptors."
  • Michael Carroll Nov 06, 2014
    not the adapter, you probably have a bad power Jack where the adapter plugs in to. if the Jack is bad it don't matter how many adapters you try the power will not flow in to the unit.
    http://www.casiokeyboardjunkyard.com. this is a website where you can order a new replacement dc power Jack. it will require you to disassemble the keyboard and remove the old Jack and solder in the new one. if you don't know proper soldering techniques a electronics repair shop should be able to do the job for you relatively cheep. without the skills and techniques you can damage the traces in the board and cause more damage than you started out with. I repair electronics for a living and dc power Jack failure or even a broken solder joint will cause the problem your having and is quite common.
How do I get the white keys on my Yamaha Portasound PSS-470 to play if there are batteries in it?
If it works with a power adaptor then it should work with batteries.
The power adaptor will need to be unplugged.
The batteries will need to have charge.
The batteries should be connected the correct way around.
If all of the above is correct then there is an internal problem that will require investigation.
Dec 28, 2014 | Yamaha Music
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i
Some possibilities:
  • Damaged on the DC-IN socket.
  • Broken solder joints on the center pin of the DC IN socket (see figure: pin 1 on DC208B).
  • Damaged (broken) in D2 or R54
Aug 18, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
No powerfrom the outlet source
The AC adaptor of my Casio Keyboard has reversed polarity from the Standard Power AV adaptor you get in the market. The center is NEGATIVE. When you try to use a new power supply that is NOT a CASIO original, you may need to reverse the polarity of the plug. Check that.
Jun 29, 2013 | Casio CTK810 61 Key Keyboard
Hi, I have just bought a casio CT-670 keyboard ( very old I know). It was not working when I bought it. I have taken the back off and all looks well except for the power wires. They are attached to DC 9V...
This service manual should be close to your unit... it is a CRK671:
http://elektrotanya.com/casio_ctk671_sm.pdf/download.html
Scroll down to "get manual" and click on it to download. IGNORE other download links.
Power input schematic is on page 10, lower right corner. They appear to "or" in the batteries with the adapter if adapter is used. Look for the diodes and also the bifilar power inout filter.
Jul 28, 2011 | Casio Music
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
I havn't used my UM300 in only two days, last time it was working pretty well ... better than ever, today morning i woke up and tried to use it, but all im getting from the amp is a buzz in a very low...
Dead battery or disconnected power adapter. Leaving cables connected discharges battery in a day as this is what switches the battery on. (The input cable)
May 24, 2011 | Behringer Um300 Heavy Metal Distortion...
My Behringer fx600 multi effects pedal flashes rapidly when used with a power adaptor. this happens whether the pedal is turned on or not.
The LED is ALSO used as a battery condition indicator... this is probably indicating the battery is expired. The manual sure doesn't say much!
Apr 26, 2011 | Behringer Fx600 Multi-fx Digital Stereo...
Music Logo
43 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
