Question about Amana Refrigerators
How do a fix a refrigerator which makes a clicking noise when light in freezer is off? If I open the freezer door it stops. If the door is open and I depress the light switch, it starts the noise aga
Model AFF2534FEW3
    Novelist:
  • 167 Answers
That's a weird one. It sounds like the switch operates a relay that cuts off power, and the relay is "chattering." If so, the only way to stop it is to replace the relay. Call a technician if you're not comfortable getting into the inner workings of your freezer yourself.
Posted on Nov 06, 2014
aborcass
  • 2651 Answers
SOURCE: Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Posted on Feb 23, 2008
SOURCE: Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had the same problem. One morning I opened the doors to a hot fridge and burning plastic. The light housing was sizzling hot - much of the unit literally melting away. Another hour or two and it could have been much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes of patient talking, I learned that Sears (or Kenmore) have issued what they refer to as a "flash warranty) on the light fixture kit (Kit # 6871JB1423N) which in effect, for this part only, extends the factory warranty from one year to three years. I may even be able to have a factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: A very unusual 'croaking' frog like noise from the
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Posted on Jan 13, 2010
SOURCE: my LG refrigerator model #
my refrigerator before making a loud noise when we open the door. i called mr.apliance he replace the evaporator fan.......
Posted on Sep 25, 2010
Daniel S
  • 4323 Answers
SOURCE: RF263 series Samsung Refrigerator just began
Hi
The sound comes when there is ice build up around the fan and the fan will hit it causing this sound. You can try to leave it unplugged for around 4-24hrs and also make sure that the area near the back is clear so that airflow can get through. If the issue returns then replace the thermostat. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 01, 2011
I have a Servis fridge freezer and it's making a clicking noise at the front at the top. Fridge and freezer working but noise annoying . Stops when u open the door. What is causing this.
Does it have a fan? If so fan may activate when the door switch closes. Open the door and hold switch then and check for noise.
Jan 20, 2016 | Refrigerators
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
The unit is making a short cranking noise.
Sounds like the freezer fan motor to me.
Open the freezer door.
Push in and hold the light switch on the door and listen for the noise.
It will probably be at the back of the freezer where the fan motor is located.
Could be a motor going bad or a ice buldup around rge motor blades.
Jul 31, 2010 | Jenn-Air JSD2695KES Side by Side...
It is making a buzzing noise on freezer side that stops when u open the door but starts again when u close it
On some models of refrigerators, the evaporator fan (behind an access panel at the top of the freezer) shuts off when the door is opened. This fan may be making the buzzing sound.
You should be able to check by pushing in the door switch while holding the door open. The fan should come on; and, if the buzzing resumes, you know what is making the noise. The fan may be developing a problem. If it stops running, the cold air will not be distributed properly between the freezer and refrigerator.
Oct 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
Sep 10, 2008 | Refrigerators
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
111 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
