E065 - Office Equipment & Supplies
Jam code E065
do Chang r a d f sensor
Jul 09, 2014 | Toshiba e-Studio 350 Copier
Tip
ERROR codes Canon 6230
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6035
Canon 6035 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controller
My canon ir 7105 show E065 , i change the primary charger assembly still the same plz help me
E065 if you already change primary corona assy and the problem is the relay pcb , you can found it in the lower left side of the machine, i encountered it twice check if the fusible resistor is busted , if faulty u can jumper it using wire.
Apr 02, 2012 | Office Equipment & Supplies
I have a 1992 cadillac and when you drive this car it will just die you can restart the car and go again and when you least expect it. it will just die. took it to the shop and the said they had a code for...
(E027) Open throttle signal switch {unplugged throttle position sensor, sensor out of range, open circuit in wire. Usually fixed by replacing the sensor but you should check the wires.}
(E040) Power steering Pressure switch open {same as throttle position sensor.}
(E065) Cruise - SPS Failure {This one is strange. It can actually indicate an overheating or under-heating engine. It turns the cruise control off if the engine gets too hot or stays too cold for too long. Of course, it can also mean the cruise servo position switch has failed}
Apr 19, 2011 | 1993 Cadillac DeVille
E065 canon NP 6030
If I rember correctly, Your transfer roller unit is arching out. I would first clean off the loose toner in the unit & from the seperation unit. You will need to remove the transfer roller unit. If that dos not clear the code you will need to replace the transfer roller unit. Good Luck
Mar 10, 2011 | Canon NP 6035 Copier
Trouble E065 WITH CANNON 6230
ERROR E065-Composite Power Board or DC Controller
Jan 11, 2010 | Canon NP 6230 Copier
E065 error
E codes are usally associated with copy jams check all paper drawers for paper jams and display panel indicator to see what area is lit and then check that area for trapped paper.
Jan 15, 2008 | Canon NP 6035 Copier
Troubleshoot
Désolé car j'ai le méme problème et je trouve pas de solutions, un code d'erreur E065 puis ca bloc avec un bourage, c'ent ambétant car ca me fait perdre beaucoups de papier. merci de m'aider
Nov 27, 2007 | Canon NP 6035 Copier
Canon ir 8500
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
Sep 09, 2007 | Canon imageRUNNER 400S Copier
24 people viewed this question
jasbo
jasbo
