Question about Hotpoint  14.9 Cu. Ft. Top-Freezer Refrigerator
<!-- from fixya rte -->How to flip a door on hotpoint fzfm171 - Hotpoint &#194; 14.9 Cu. Ft. Top-Freezer Refrigerator
    Sergeant:
  • Hotpoint Expert
  • 448 Answers
Handle and hinges all removed to opes it side little plugs are in door and ref for this middle hing may bet turned upside down or pin removed to different hole if not handy call a service co. this is not easy all the time make sure all spacer washers are in same place when re installing take pictures as you take apart
Posted on Mar 24, 2015
I asked a question about Hotpoint self cleaning oven but I don't know where to look for answer
If someone has answered it, two things happen.
You get an email notification to the account you logged on with.
You will see a red '1' at the top of the page where the Bell icon is. Click on the Bell and a box drops down with info.
Self cleaning oven programs are a pain. They burn out elements and very often after the cycle, the door won't open.
If the oven isn't heating up now, it has burnt out the elements and they need replacing.
If the door won't open, try flipping the breaker for 30 seconds.
i found your question. Flip the breaker to reset.
I started the self cleaning oven but because of breathing issues, I shut it off after running about 45-60 minutes. Light is blinking off and on then stops then blinks again. What should I do?
Finally, if you get an answer, and to want to reply, click COMMENT under their post.
started the self cleaning oven but because of breathing issues shut it off...
Nov 22, 2017 | Hotpoint Kitchen Ranges
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Jan 27, 2016 | Hotpoint Refrigerators
Hi, I have a hotpoint fridge/freezer future rf 175wp and want to change the doors from right hand to left hand hanging. Do I need to get new hinges? Thanks Dave Horn
Dave,
You should not need new hinges. As long as you have screw holes on both sides you re-use the same hinges, just flip the middle one over. The bottom hinge point, you will need to move the post from one side to the other. Hope this helps!
May 07, 2015 | Hotpoint Refrigerators
Door does not lock shut but machine still works. Is it easy to repair?
Exactly the same happened to our Hotpoint FWD70. The spring that holds the door latch in place has snapped. I removed all screws out of the door to find the spring and the metal rod it hooks onto and bend another hook into it (I didn't have a replacement spring), put it back together and the door works fine, although for some reason the dishwasher tablet doesn't release now!!
May 19, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint wf220 glass door
undo door hinge from cabinet - held with two screws.
the door halves are held togethet with a few screws which undo and the door will split apart so you can replace the glass
Oct 02, 2008 | Hotpoint Aquarius WF220 Front Load Washer
FDW60
I have exactly the same problem, please let me know if you find a solution and I will do the same.
Sep 21, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Aug 25, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint ultima washer dryer
isolate from mains. undo door gasket and check interlock id ok. interlock is mounted on cabinet on rhs
Mar 11, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint &#194; 14.9 Cu. Ft. Top-Freezer Refrigerator Logo
70 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
