Question about Refrigerators
Ff4d 2 door left freezer door open all night now all 3 lights are on i have switched it off for 24hrs and switched it back on but all 3 lights are still flashing ?
  • James Drain
    James Drain Nov 06, 2014
    i have switched it off for 24hrs with doors open and switched it back on with the fridage compartment switched off hoping that the freezer gets to -18 then after 24hrs im told to switch fridge compartment on
HVACRH20
  • 237 Answers
SOURCE: Freezer left open and now won't work
Try to unplug the unit from the wall and let it sit for a few minutes then plug back in. May reset the door alarm lock out. Also, moisture in the air can be drawn in and freeze up the whole thing. That means turning it off with doors open for about 36 hours... Moisture is a killer in a freezer, freezes and blocks up every air circulation vent, etc.
Posted on Nov 09, 2006
SOURCE: flashing lights super chill super freeze
This is probably because you turned off the fridge at the mains (to defrost??). To stop the flashing lights and to restore normal operation, turn both the Supercool and Superfreeze knobs counterclockwise to "off" and then back to the operating position. Thats all!
Posted on Jul 06, 2009
  • 6 Answers
SOURCE: Sharp SJ-42-WH self-defrosting fridge. Freezer
I recently had exactly the same problme with this model refrigerator. I found the problem to be the defrost timer. It is located behind the panel on the back of the refrigerator where the mains cord is located, you will need to replace it with the exact same model. I am in Australia and managed to find the exact part on ebay cheaply from a local appliance parts supplier, any appliance parts supplier that deals in Sharp refrigerators should be able to help you.
You will have to defrost the refrigerator overnight again before doing this repair.
Of course there are a couple of other components that could cause this problem, you can acutally check to see if the defrost time is moving by taking note of it's current position and then checking it every thirty minutes or so. If it does not move then it could be faulty, make sure also that power is getting to the timer as well.
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: A very unusual 'croaking' frog like noise from the
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Posted on Jan 13, 2010
  • 1531 Answers
SOURCE: We left the freezer door open all night...now the
the freezer needs to be shut down for a whole day in order to defrost the evaporator coils completely.
this can also be done by removeing the rear panel in the frezzer and using a blow dryer until all the ice is gone and then the unit should return to cooling normally
Posted on Jun 03, 2010
Sorry its a hotpoint quadrio FF4d I left freezer door open for a few hrs and now lights wont stop flashing
This sounds dumb, but it often works with electronically controlled appliances. Unplug the refrigerator from the power socket and wait a few minutes. Then plug it back in. That will reset the electronics and may solve your problem.
Oct 31, 2014 | Refrigerators
The freezer is working fine, Iv tried rebooting the fridge but it's not cooling at all :( my son had left the fridge open all night....
Try turning the temp setting to '0' pull the wall plug out and leave for 2 - 3 hours with door open. Plug in switch on and set temp to max. close door and leave to cool. This should work.
JS,
Dec 28, 2012 | Refrigerators
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
If your fridge is left open over night and it wasnt closed till morning and the alarm light does stop flashing when it is closed what does that mean?
Hi and welcome to FixYa, I am Kelly.
FYI... The door alarm will sound anytime the door is left open for more than 4 minutes.
Per your post... What it means your refrigerator is working normally.
However... there is the possibility of having excess ice build up on the evaporator coils from the door being open all night. If the freezer section starts warming up due to poor airflow you may have to do a manual defrost. You would first notice the lack of ice production or soft ice cream if there were air flow problems due to excess ice on the evaporator coils.
To do a manual defrost all you do is:
1. Unplug the unit
2. Remove freezer contents
3. Use a fan directed at the freezer compartment for just over 2 hours (makes a water mess)
4. Reload the freezer
5. Plug in the refrigerator
Everything should be back to normal in just over 4 hours except ice production that can take up to 8 hours.
Thanks for choosing FixYa,
Kelly
Nov 21, 2010 | Whirlpool Refrigerators
My whirlpool freezer was left open by my child and now is emitting a buzzing noise. What is this noise and what do I need to do to fix it?
You may have frost bulidup on evaperator from door being open and fan blade rubbing on ice. turn off to melt the ice 8 - 24hrs then turn back on
May 17, 2010 | Freezers
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Elite Trio 795.7519
Either you have accidently left the door open at some time in the last few weeks or you have a faulty defrost sensor, initially turn off defrost freezer over night with doors open, turn on following day, unit should start to work within 12 to 24hrs, other wise replace defrost sensor but still deforst. Regards Advisor
Aug 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
