My logik L612WM13 displays e12 on screen mid cycle . tried turning of and on / filter ect
2 Suggested Answers
latino319
  • 7 Answers
SOURCE: I have a Bosch washer and it keeps stopping mid cycle and has a error code e12. We already checked the drain filter and there are no clogs.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back If not properly leveled, the water can flow back into the machine. If this is the cause of the problem,
Posted on Jan 20, 2018
Jan 19, 2018 | Bosch Washing Machines
MY LOGIK WASHING MACHINE MODEL L612WMS13 SHOWS ERROR 12, THE POWER WENT OUT WHEN THE MACHINE WAS STILL WASHING AND WHEN IT CAME ON IT DIDN T CONTINUE THE CYCLE AND THERE IS STILL WATER INSIDE
Remove the wall plug which _should_ reset the main board. If that doesn't work, you have to manually drain it by unclipping the drain hose and lowering it into a bucket.
Error 12 (E12)
Washing machine has detected an overfill situation This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
  • Check for overfoaming or over soaping
  • Check the air chamber and the pressure switch hose
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3848-logik-washing-machine-error-codes
Jan 20, 2016 | Washing Machines
Logik manual
think logic stuff made in turkie
Jul 25, 2014 | LG WM Washing Machines
How to reset service engine light on 2013 Isuzu NRR truck after changing engine oil?
Resetting of 'ENG OIL&FILTER'
When the reset is done, the display of 'ENG OIL& FILTER' will be reset to 10,000 mile (16,000 km).
  • Press and hold the MID select knob at the 'ENG OIL& FILTER' display screen > The reset screen will be displayed > Press and hold the MID select knob
Jul 30, 2013 | Cars & Trucks
Drawer stopped mid cycle
Have you tried to turn the mains power switch off and on to see if it resets the drawer to off state. Need a bit more detail of what you see on the display etc. when you try to turn back on.
Dec 10, 2012 | Fisher and Paykel 23 in. DD-603 Built-in...
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
What does it mean when the machine stops mid cycle and H and then F displays in the digital window?
I think that means NO, Hot water Flow (HF)
Try this Hold the "Start" button IN while you Switch ON.
Also check this out pull the water lines filters to check the screens, and the cold water line for crud in it
Feb 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Thermador prd486edg oven/heating flashing 1/2and neither oven heats. help!
only code that is close ( e12) ( E12) look at display and make sure .. mm if the code is E12 then " CT oven:latch switch problem ) this may help Note E . 1 turn the clock selector knob to off 2 tweak the oven control by turning the clock selector slightly to the left ( counter clockwise ) this may stop the flashig message / beeping and clear the display window. " try it and pray mm .
Dec 09, 2009 | Thermador PG304BS Gas Kitchen Range
Washing Machines Logo
213 people viewed this question
Top Washing Machines Experts
