Question about Eiki LC-XL200 6000 ANSI lumens XGA Projector - Power Zoom and Focus Lens
<!-- from fixya rte -->How to reset the warning filter lamp? - Eiki LC-XL200 6000 ANSI lumens XGA Projector - Power Zoom and Focus Lens
RESET SERVICE WARNING LAMP
the warning lamp is a oil change indicator to turn it off, remove the little rubber plug on the lh side of instrument panel switch ignition on insert a suitable object ie. cocktail stick press the button inside the light should go off, change the engine oil and filter if you have not all ready done so. hope this helps,
Sep 23, 2016 | 2006 Toyota Hilux 3.0
Reset diesel filter sensor
Switch the ignition to OFF.
Disconnect the fuel filter warning lamp switch connector.
CAUTION: Never depress the brake or clutch pedal.
Switch ignition to ON. and wait for 3 seconds.
Next during the 57 seconds re-connect the fuel filter warning lamp switch connector.
After further 3 seconds the fuel filter warning lamp will go OFF, or the message "Fuel filter maintenance required" will be cleared off from the display and the re-set is complete now.
Switch OFF the ignition switch.
Nov 23, 2013 | Toyota Land Cruiser Cars & Trucks
On the bottom of my hitachi teleiviso below the power button theres 2 other lights blinking saying temp and lamp and so far none of these have offered up the information on wether i need to buy new parts...
hi there.
the lamp light is lit to warn you that the bulb is ready to expire,if it hasnt already!
fit a new lamp and then reset the lamp hour counter using the on screen menus.the temp light is lit to warn that the filters near the fan want cleaning!
hope this helps
regards,steve
Jul 31, 2011 | Televison & Video
Warning lamp blinks red. Tried new bulb just for kicks, but not the problem. Any ideas?
Time to clean the air filters. See manual how to clean air filters and reset the filter cleaning counter in the device.
Feb 16, 2011 | Sanyo PLC-XU101 Projector
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
The clean your filter warning sign comes up and then shuts the projector down in 1 min. I have changed the lamp and filter. How do i reset the timer for the Lamp Hours and get rid of the warning?
Once the filter is replaced, plug the projector back in and make sure the projector is in standby mode.  Point the remote control at the projector and press the following buttons in order in less than 3 seconds: reset, ←, →, enter.  This worked for me.  Good luck.
Feb 21, 2009 | Sony VPL-VW100 (Ruby) Multimedia Projector
Replace lamp warning light goes on after raplacing it with the new lamp
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Jul 21, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Eiki LC-XL200 6000 ANSI lumens XGA Projector - Power Zoom and Focus Lens Logo
95 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
