Question about Ovens
IS THERE A WAY TO BAYPASS THE DOOR LOCK MOMENTARY CONTACT SWITCH CIRCUIT THAT LOCKS OUT THE OVEN RESPONDER ON AN OLD GE OVEN MODEL NUMBER J 348B2WH WHICH ACCORDING TO GE WAS MADE IN 1945
THE OVEN RESPONDER FAILED, AFTER MUCH SEARCHING I FOUND WHAT I THOUGHT WAS AN EXACT REPLACEMENT BECAUSE THE PATENT NUMBER ON THE PARTS WAS IDENTICAL WHICH WAS THE ONLY NUMBER THAT I COULD COMPARE. WHEN THE PART ARRIVED IT IS IDENTICAL EXCEPT FOR ONE TERMINAL THAT IS RIVETED ON THE OLD PART, THE NEW PART HAS THE SAME RIVET BUT THERE IS NO TERMINAL TO CONNECT A WIRE. THE INTERNAL CONSTRUCTION IS IDENTICAL, THERE IS A WIRE ON THE RIVET ON THE INSIDE OF THE NEW PART BUT NO WAY TO CONNECT A WIRE EXTERNALLY. THE WIRE THAT CAN'T BE CONNECTED GOES TO A MOMENTARY CONTACT ON THE LOCK SWITCH. I TAPED OFF THE WIRE AND THE OVEN ACTUALLY WORKED ON SUNDAY 11-2, BUT ON TUESDAY 11-4 I TRIED THE OVEN AGAIN AND THE INDICATOR LIGHT THAT CYCLES ON AND OFF WITH THE OVEN ELEMENT COMES ON FOR ABOUT 3 SECONDS AND THEN GOES OUT.
1beertap
  • 32 Answers
SOURCE: ge oven door locked
You oven is locked because it is self-cleaning. Some how the handle got moved and it initiated. You may need to let the oven finish self-cleaning. Usually, it can take about an hour to complete the process. Afterward, the oven will beep when done and your oven can be opened. Good luck.
Posted on May 31, 2007
Krazytech
  • 725 Answers
SOURCE: Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Posted on Jun 04, 2008
  • 116 Answers
SOURCE: ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Posted on Aug 31, 2008
jandj_web
  • 3 Answers
SOURCE: Replacing ERC on GE oven
I ran into the same problem replacing my new part. The instructions indicated that the GROUND wasn't used. The Nuetral was located in near the same position. The L1B went to the little black box near the vacant L1B location on the board
Posted on Dec 01, 2009
heatman101
  • 43501 Answers
SOURCE: GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Sep 30, 2010
GE Adora JGB605DET3WW after self clean door would not unlock. Tried shutting of breaker but after turning back on still the same. Replaced door lock motor with another one and circuit board and still...
Press the oven light switch in and see if the it returns to normal. The oven light switch is part of the self clean circuit and it is is not depressed or not working then it could be the entire problem. If pressing the switch in cures the problem, then the switch is working fine and the clock oven control will need to be replaced. Happy New year and have a wonderful day. Oven light switch part number WB24K10068, Oven control part number WB27K10319. when changeing out this part you have to remove the overlay with button description on it and transfer to new clock, try gentel heating it before trying to remove or the paint will rip off and you will need a new overlay here is the part number just in case WB27K10408
Dec 26, 2017 | GE Ovens
How do I find the part number for replacing control board for GE?
WB27T10290
I would not be so sure about that the problem is in the control board. Check switches on the door lock assemblies first.
Jun 02, 2010 | GE Profile JTP56 Electric Double Oven
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
I have moved into a house about 11 years old. I started the self clean and now about two hours into it an alarm is going off signifying "F2 door locked". Can't turn off alarm :-( Don't know part...
F2 During CLEAN The Control is senses oven temperature above 915F-930F. If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC). If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches. Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jun 03, 2009 | GE Ovens
E1 f2 error
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
Good Luck
Sep 05, 2008 | GE Profile JT912 Electric Single Oven
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
Ge oven problem
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Missing manuel Code showing - F 2 -
hi,
F2
F2
Oct 31, 2007 | GE Profile JT912 Electric Single Oven
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
