Question about Autodesk AutoCAD Computers & Internet
.dwg file corrupt?
I keep getting an error when importing this file. Is it corrupted? If someone could open, resave and repost here I would appreciate it. Thank you.
    New Friend:
Different solutions you may find out here:-
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/444-%E2%80%8Berror-cannot-open-file-open-cad-drawing-dwg-format - a lot of different opinions might be your saving.
BAK files are very important, explanation below:
Consider what AutoCAD does during a QSAVE (assuming "create BAK" is enabled)
1. It writes the contents of the editor to a temp file.
2. It renames the current drawing from .DWG to .BAK
3. It renames the temp file to the correct file name with a .DWG extension.
I don't see how you have had problems with BAK files since it's simply a copy of your last save. In fact, if you QSAVE twice in a row, then your BAK = the DWG.
OR
Third party software DWG Viewer Tool
But demo version for free:- http://www.dwg.viewertool.com/
Posted on Nov 06, 2014
My valuable .dwg file has trouble
If a file cannot be opened, take the following steps for repair dwg
In case it can't be effective, then you have hard issue, see and learn more professional articles, guides and etc.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-repair-AutoCAD-Installation.html
http://www.thesourcecad.com/recover-damaged-or-lost-autocad-files/
https://dwg.recoverytoolbox.com/
  • RECOVER command
    --Recovers a selected drawing file
    --If successful, open and run AUDIT command
    --Evaluates drawing integrity and possibly more error correction
    --Set system variable AUDITCTL=1 to create a report of audit results
  • RECOVERALL command (introduced in AutoCAD 2008)
    --Attached and nested xrefs are also opened, repaired, resaved, and closed
  • INSERT and EXPLODE
  • Start a new DWG with no template
    --Run INSERT and selected the corrupted drawing
    --Check the "Explode" option
Mar 20, 2018 | Autodesk Computers & Internet
Autocad changes lost
The most effective solution is .dwg recovery tool when other methods don't work
The place where you may read various thing about Autocad
Here you may read more about article below
However, a few things may get it to open:
  • Try to open the drawing file directly instead of using the Recent Documents menu.
  • Check that the storage location that holds the drawing is working properly.
  • Use the RECOVER and RECOVERALL commands on the drawing.
  • Attempt to insert the damaged file into a clean drawing or template using the INSERT command.
AutoCAD Recovery tool How to repair corrupt AutoCAD drawings and fix its errors Error Drawing file is not valid when opening file in AutoCAD
Aug 28, 2017 | Computers & Internet
My autocad dwg files have been corrupted
Displays a list of all drawing files that were open at the time of a program or system failure. You can preview and open each drawing or backup file to choose which one should be saved as the primary DWG file. After a program or system failure, the Drawing Recovery Manager opens the next time you start the application. Drawing Recovery Manager displays a list of all drawing files that were open. The System Variable RECOVERYMODE controls whether drawing recovery information is recorded after a system failure and whether to show the Drawing Recovery Manager or not.
If you want to help yourself, Autodesk and other AutoCAD users make sure to send in any errors to Autodesk when you see the Customer Error Report dialog box (CER).
Finally a solution that sometimes helps if AutoCAD cannot fix the problem is to try to fix the drawing in another program that can open and save DWG files. The more users having the similar problem the better chance it will be fixed in a service pack or future version. Eventually you might
get DWG Restore Toolbox saying the problem is fixed.
from website: http://www.dwg.restoretools.com/
Jun 20, 2015 | Autodesk AutoCAD 2010
How to view damaged dwg file of autocad?
Try using a different version of AutoCAD to open the drawing, such as AutoCAD 2013 vs. AutoCAD 2015 or plain AutoCAD vs. AutoCAD Architecture, etc. Try different computers if available. or try DWG Viewer Tool on website:http://www.ask.com/answers/722146801/how-to-view-corrupted-autocad-drawing?qsrc=14106
May 29, 2015 | Autodesk AutoCAD Electrical 2013
Corrupt DWG files
AutoCAD RECOVER command?
If doesn't help, try it:
DWG Repair Kit
This professional AutoCAD DWG repair tool features a uniquely efficient data analysis core and an interface that both professionals and novices with appreciate. The program will show you how to repair DWG files online in seconds even if you have never worked with data recovery tools of any sort!
For more information: http://www.dwg.repair/
Also look here: https://social.technet.microsoft.com/Forums/en-US/fb2d8693-9551-43b7-9310-584471d60a56/autocad-files-corrupted?forum=w7itproappcompat
Feb 17, 2015 | Autodesk AutoCAD 2007
How to recover AutoCAD files from flesh card?
If you need to recover it as fast as it possible install Recovery Toolbox for DWG , this thing is able to help you. But it's not free. Download free demo here:
http://www.dwg.recoverytoolbox.com/
As one of solutions I can advise you to try to open your files in MS Visio, Compass or using another program which could open dwg file. Or try to recover them using AutoCAD recovery function.
Also you can read here about dwg file corruption:
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/561-how-to-recover-autocad-files-from-flesh-card
Nov 27, 2014 | AcroCAD Software AutoCAD DWG to PDF...
How to recover a autocad dwg. file from bakup file
You may recover .dwg file with dwg corrupt file repair
Material http://www.autocad.repairtoolboxx.com could be interesting for autocad files
Feb 07, 2013 | Computers & Internet
True view corrupt file: I can load a drawing directly from an Email attachment but when I save the file and then try to open the same drawing from that saved file I get a 'Drawing file is not...
Given trouble can resolve with the help of dwg recovery. It work with big autocad files corrupted and deleted after power failures, viruses, malicious software. The software has modern user-friendly, agreeable interface.
Sep 26, 2011 | Autodesk DWG TrueView
Opening dwgs in autocad
In the past the fastest way to fix this is to go directly to the file and try to open it. It is possible that file or database has been corrupted. In some instances the file type dwg is not associated with autocad and the application hangs because it is looking for .dwg as an associated file type to autocad.
Let me know if you need further clarification.
Apr 08, 2009 | Autodesk AutoCAD 2004 for PC
Computers & Internet Logo
121 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
