How do i get cd player to work on 2003 magna
My battery was disconnected (while being tightened) noe since then error comes up E--2
SOURCE: 2003 Ford Focus Blaupunkt Cd Player issue!!!!
I hav an 03 and it exhibited the same problems; on off on off nothing works. I discovered this repair 2 days ago and it works perfectly and I am one happy camper.
1. Start by pulling the main fuse for the radio (if you already haven't)
2. Re insert the fuse and turn the radio on (nevermind the on off sequence). Insert a music CD, it will take one.
3. Pull the fuse again, count to five and re insert fuse.
4. When the CD starts to play, use the menus to get down to the factory default settings and ask it to reset to factory.
5. And you are now working again. Or you should be. It basically is a processor and it operates just like your home PC whn it needs a reload. It searchs to the default drive which is the CD player.
Good Luck everyone!
Posted on May 04, 2008
  • 398 Answers
SOURCE: CD error 2001 Mustang GT
battery, if it works.
Posted on Mar 05, 2009
SOURCE: Error 1 in Toyota CD Player
i want toyota camry 2008 model single {CD} machanism . I need {CD} machanism . With price please send me this price @ [sassaad95@gmail.com] ok
THANKS ! happy NEW yEaR
Posted on Dec 31, 2009
caroldon
  • 17129 Answers
SOURCE: Problem for Blaupunkt Bermuda MP36 Car CD Play
It is possible that if your normal standard recording are working fine, then the format of the MP3 is not recognised. If so please try and rerecord on the acceptted format. If this MP3 was playing earlier to the fault then it is a possible failure of the processing section. If your cd is not reading but ejecting out then it is a fault in the optical for a possible weakening of the the laser. If you have warranty claim for this failure. however if it is readding but there is no output please check as above with a standard mp3 format. Howeverr if there is sttill no result I beileve you will have to get the main board replaced. If you are familiar with electronics you have to check within for the RF and signal to confirm for the suspected stage. however attempt only if familiar. Hope you follow this guidance. Good day
Posted on Jul 13, 2010
caroldon
  • 17129 Answers
SOURCE: Problem for Blaupunkt Bermuda MP36 Car CD Player.
The fault was explained earlier, please check your MP3 format. play a normal cd to see if it detects, if so try with another recognised MP3. if not clean your head after opening the set. try again or it is possible that your optical is faulty or the RF signal processor IC is defective. Check this out. Good day
2010 Kia Rio 5 .Radio works but CD player doesn't. It displays Code 5 error.Any idea on how to fix??
Cd Player Error - Kia Forum
www.kia-forums.com/2003-2010-sorento.../59783-cd-player-error.html
May 11, 2010 - 10 posts - ‎5 authors
... Kia Picanto Forum · Kia Rio Forum · Kia Sephia Forum · Kia Sorento ... Have tried a whole range of CDs (copies and originals) but doesn't like ... If the negative battery cable idea doesn't work, try to remove the .... Last edited by pulsar86; 05-13-2010 at 01:42 AM. ... 5 Attachment(s) Kia elan T8D engine vs. Change Rear/Front Speakers 2006 Kia Rio (for ...
Jun 28, 2011
Resetting the radio - Kia Forum
Jun 9, 2011
Kia picanto 2010 cd player removal and mp3 - Kia Forum
Dec 29, 2010
Replaced battery and cd player/radio quit playing ...
May 7, 2008
More results from www.kia-forums.com
Remove Power Supply Fuse For Twenty Seconds if CD ...
Dec 27, 2015 | Kia Cars & Trucks
My odyssey 2003 is showing code err for the entertainment
Does the radio work at all. or is the cd player the only issue.? most of the time you need to enter a radio code to unlock the radio. If you enter it wrong to many times it will display error on the display.if you dont know the code then you can call the dealership and get the code after you do the following below to get the serial number.
Press and hold 1 and 6 on the radio while still holding the 1 and 6 press the power button. At this time it will read off serial number
SOUTHERNELECTRONICS.COM
Apr 02, 2015 | 2003 Honda Odyssey
When i try cd it keeps writing error.and reject every cd plates i insert.it was playing normal 2days ago.pls what do i do when error notice appear.the car is honda 2003 model coupe.thanx
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 2003 Honda Accord
Cd door wont open. Trying to load and nothing happens. Keeps saying "cd error" but it doesn't have cd's inside. can you help me?
the cd reader eye is bad, caused by vibration or dirty cd's. Disconnect the battery cables and wait 2 min then reconnect. star engine wait 2min and try cd player. if does not work you need a new cd player.
Jan 15, 2010 | 2003 Ford Expedition
CD player not working correctly
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
Jul 29, 2009 | 2003 Ford Escape
CD Player not workinig
Try using a cd player cleaner disk, then remove the radio fuse in the fuse block wait about five minutes then re-install. This is done to restart the radio. If that don't work disconnect the negative from the battery, wait five minutes then reattach, this will restart the cd player for sure. This will also restart the car computer just so you are aware.
May 12, 2009 | Car Audio & Video
Six-disc cd player
I too have this problem. My alternator went out, however and when starting the car after having that replaced it must have reset my CD player and it worked again for about 2 months. I am back to the CD error again tho. Thinking of un-hooking my battery cables to see if that will reset it again.
Apr 01, 2009 | 2003 Mercury Mountaineer
Ford Expedition 2003 6 CD changer contianing 6CD's says CD error
Try unhooking the battery for 5 minutes to reset the stereo
Feb 25, 2009 | 2003 Ford Expedition
03 vibe cd player will not respond
I blew a fuse controlling the radio, charging system, turn signals, heater fan, ,etc..this ran down my battery.
When I replaced the fuse, the CD player would not respond, but the radio worked.
I disconnected the battery for over 30 seconds, hooked it back up, and the time reset on the radio to 12:00 and the CD player works again.
Jan 23, 2009 | 2003 Pontiac Vibe
PLAYS CD BUT COMES VACK NO DISK WHEN YOU TRY TO LOAD DVD .ALSO LO
The laser (optical pick up) need repalcing usually an uneconomical repair in view of the low cost of DVD players noe.
SUPER8
Nov 12, 2008 | Televison & Video
 Grubhead
Grubhead
