Question about Canon PIXMA Office Equipment & Supplies
What does the orange flashing light on the Canon Pixma 2450 mean?
It is only after changing all the ink cartridges, and discovering it would not print, and made a loud BRRR-ing vibratory noise, and now it just has the silent flashing orange triangle with the bolt inside. It does not print. Help me?
  • 47 Answers
SOURCE: Installed new cartridge in canon pixma mp210 & now can't print
The printer needed to be reset.
Unhook the printer then take out the new cartridges.
try to very gently clean the contacts also make sure the contact on the new cartridges is clean.
Let it dry for a few minutes assembly.
Plug it. My printer is reset by pressing the start button and hold it down until it beeps 6 times.
You can check your manual how to reset yours.
I hope it work for you.
Posted on Mar 17, 2009
  • 232 Answers
SOURCE: Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Posted on Apr 07, 2010
pineworks
  • 4041 Answers
SOURCE: my canon pixma ip3000 will not print in black ink
Hi There
Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
SOURCE: Canon i250, black text won't print, but ok with nozzle check
Canon i250. Instructions on this website solved the problem of flashing green and orange lights, but now the black won't print. Changed ink cartridges, but still no print. Did a diagnostic nozzle check, and the black DID print. What do I do now?
Posted on Jul 31, 2010
  • 2246 Answers
SOURCE: What does a flashing orange
your cartridge or cartridge carier has problem
open printer door, check cartridge, if cartridge ok, close printer door then
press orange light button for more that 2 minute, for me it always work
i hope this helpful
thank you for using fixya
Posted on Mar 12, 2011
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
7 orange light flashes and 1 green light flashes
This means that the ink cartridges have not been installed correctly.
Make sure that the black ink cartridge is installed in the left socket and the colored is in the right socket.
Make sure that you hear the click sound confirming that the cartridge has been placed correctly.
Sep 18, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma IP4000 - Printer on/off button flashing orange light X 5 and then green. I have just re-newed all the ink cartridges Can you help ? will i be able to re-set printer ?
5 times orange means you need to replace the print head.....if the led are Blinking in Orange and Green Alternately you need to replace the sheet feed unit.
Mar 28, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
7 orange flashes and then one green..what does that mean?
7 orange flashes of the alarm lamp means that FINE cartridge is not installed in the correct position. Confirm that the FINE Cartridges are installed in the appropriate positions.
Please refer to the link below to see document on replacing FINE cartridge http://support-ph.canon-asia.com/contents/PH/EN/8200182600.html
The link below gives you information regarding Causes and Solutions when Alarm Lamp Flashes Orange http://support-ph.canon-asia.com/contents/PH/EN/8200187300.html#5
Mar 23, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
What does a flashing orange light mean on a Canon ISMA iP1900 ink jet printer? It refuses to print.
i hope this helpful
Mar 12, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
The orange lamp always lights
depending on how many times the orange light flashes. if 4 flashes then the ink has run out. if 5 flashes then it can not recognise the ink cartridge, if 7 flashes then the ink is not installed properly.
Mar 31, 2009 | Canon PIXMA iP1800 Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
110 people viewed this question
old marine
old marine
