Question about Ricoh CL4000DN Laser Printer
How do I get the meter count
Need direction on how to get to counter
    Champion:
  • Ricoh Expert
  • 208 Answers
Print the configuration page.
Posted on Nov 23, 2014
How can I convert Ricoh development counter to pages
Best thing to do is contact Ricoh Services and Support (1-800-432-9787) for service. A Ricoh Tech/Engineer would need to go into Special Service to change the Accounting type preferences, as end-users shouldn't have access to this Special Service function. Additionally, once this change has been made, you cannot revert back; you can only change this setting once.
Jun 02, 2014 | Ricoh Aficio™ SP-C210SF Printer
How do i find the w&b numbers to input for my monthly meter reading?
User tools button then counter then select print counter that will give black and white total count use that number
May 31, 2014 | Ricoh Aficio MP-201 Copier w/ Duplex...
How to remove on screen preventive maintenance time m5
there is no M5 preventive maintenance only M2 and M3 please conform
May 10, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Service mode bizhub 421
Utility/Counter
Meter Count
stop 00 stop 01
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
Operating manual for bw 30 & bg 30 timer counter
1) Identify product on following page:
http://www.hugo-mueller.de/elapsed-time-counters/mueller-bw-30-bg-30,p,en,8,34.html
2) Sales sheet shows model numbers and voltages and shows that product is hour meter:
BW30 is AC alternating current with choices 230Vac 115Vac or 24Vac
BG30 is DC direct current 12-48VDC
http://www.hugo-mueller.de/download/34_DB_BW30_BG30_BW22_GB.pdf
3) Hour meters normally have 2 terminals, but there is not a photograph of back of product.
Hoping you will photograph your product and post image on your website and add a comment to this thread with web address of image, along with other information you have.
4) Usual set up for timers and counters: terminal 1 is for black wire L or L1, and terminal 2 is for white wire N or L2.
If terminals are not labeled, then wires can be connected either way, but as you face terminals, terminal 1 is on left.
5) Wiring:
Hour meters are wired in parallel, not series.
For example hour meter on 240V pump: 2 wires go to pump.
Simply connect each hour meter terminal to one of the wires.
Another way to illustrate: If you test electricity using two-prong tester, you touch each tester lead to one of the wires. Hour meter connects same way.
6) How hour meters work:
Hour meters count number of hours electricity is turned on.
For example I have 240V Grasslin hour meter connected to water well pump.
Water well has pressure switch that turns pump on-off.
If hour meter is connected before pressure switch, then meter simply runs continually since it receives power all the time.
So hour meter has to be connected after the pressure switch. And then meter counts only when power is turned on to well pump. This way I see how many hours my pump runs and then estimate pump cost by multiplying hours x pump wattage.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Miller Electric Manufacturing Miller...
Where is meter reading on canon imageRunner C5180i color copier?
Hi sophie,
Look to the far right of the operator contol panel, past the 9 key pad and you will see a "little button" called COUNTER check. Press it and it will tell you your meter reading.This screen can be configured "by a service tech" to allow you to view the count of up tp 6 different meter counts depending on the function you wish to monitor. The basic meter reading is named "101". That because there are hundreds of funtions that are always monitored and they name them 101,102,103 etc. 101 counts the number of sheets of paper that have exited the copier. "102" does the same except it counts 11x17 [ledger] as 2 copies as 11x17 is really 2 letter size sheets. So my company uses this meter for billing purposes so we ADD the 102 meter to the list of viewable meters. Again this can be configured to the customers needs or the service provider needs. You can set it to view just black and white, just color, or even how many copies were made at 64%. its wild. But the 101 meter is the default and cannot be removed or altered. I sure how I helped you. Please let "FIXYA" know.The pat me on the head when I do good. :-) Take care . SPINAL
Jan 28, 2011 | Canon imageRUNNER C5180i Color Copier
HOW DO I READ THE METERS ON THE KMC2525COPIER
Press System Menu/Counter Key,
Press Check the Counter,
Press Print Report, a report will print out with counts on it.
Press Close
Oct 05, 2009 | Kyocera Office Equipment & Supplies
Konica 8020 color copier: image transfer roller unit needs to be replaced , Replaced but it is not able to recognise the change
Because you have to go into service mode and clear the counter.
Utility then meter count then stop00 stop01. then touch counters then touch life clear the transfer roller.
Sep 08, 2008 | Konica Office Equipment & Supplies
Need to get the meter count on my canon 6545 copier
The meter is located on the inside left hand side right above the fixing unit.. That is called the hard counter. There is also electronic counter that can be seen in service mode, but they can be reset at any time.
Apr 25, 2008 | Canon NP 6545 Copier
METER COUNT
press utility, and there is meter counter or you can see meter count in web interface
Dec 01, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Ricoh CL4000DN Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
