Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
The temp reads 65f. when I change it to 0-33 it goes back to 65f
The fans are all working the temp will not stay to setting.
  • Official Brand Answer
  • 2,267 Answers
Thank you for your post, janet!
I understand that your Frigidaire refrigerator is not displaying the correct temperature. Is it cooling? If it is cooling it could be an issue with your control panel or thermostat not registering the appropriate temperature within your refrigerator. I would suggest performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience a display problem or that refrigerator is not cooling I would recommend reaching out to a professional for proper diagnosis and repair. This will help you to avoid purchasing unnecessary parts. I hope this is helpful. -Matt
Posted on Nov 10, 2014
SAMSUNG REFRIGERATOR
Check to see if the condenser fan is working. Samsung has a notoriously bad condenser fan motor. This is the compartment in back. Check that forst before replacing the control board.
Mar 22, 2015 | Samsung Refrigerators
I have a 2006 expedition 5.4 the temp gauge stays on cold whats wrong?
check your coolant. the temp is the water temp. Your radiator is out of water? you`ll burn out your water pump. Also check to see if your radiator fans are running constantly.
Apr 23, 2014 | 2006 Ford F-150
Air conditioner goes off when fan speed is increased
when it's on 'auto', the fan adjusts according to the temp in the car and the temp setting you have it set at. try setting the auto temp control down to 65, then hit the "-" one more time to send it to "LO" - the fan should automatically jump up to max.
Jul 01, 2010 | 2001 Audi A4
Lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Dec 10, 2009 | LG LFX25960ST Stainless Steel French Door...
I had the radiator and thermostat changed
when you had the thermastat replaced the might have put a higher temp one in and that will make it seem like it's running hot you might have to put a lower temp one in
Jun 09, 2009 | 2000 Mitsubishi Eclipse
Temp gauge stay on cold.
Switch ig. on, ground the sender unit wire for about 3 seconds see if the temp. gauge moves, if so change sender unit, if not then it is a faulty gauge reader.
Jan 15, 2009 | 2001 Chevrolet Impala
Temp gauge goes to full hot while at Idle
Check the auxiliary cooling fan for operation. As the engine temp rises, it should kick on to bring the temp down. U may have a bad motor on the fan, or more likely a bad fan switch.
Dec 22, 2008 | 2001 Jeep Grand Cherokee
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
64 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
