Push start and the motor makes noise but doesn't run.
    New Friend:
  • 25 Answers
Check drive belt
Posted on Nov 26, 2014
3 Suggested Answers
  • 14 Answers
SOURCE: Don't want to spin motor running, push by hand
So, the motor runs all the time but the belt is skidding until the drum is pushed? Apart from the belt tension perhaps being too low, the 'click' suggests that the bearings on the drum are shot, making them lock up in certain positions at rest. ,
Posted on Mar 19, 2010
Testimonial: "Sounds like the problem a bearing shot. Th washer do all the cycles except spinning unless you pushed on that operation the motor change dirrection "
  • 1527 Answers
SOURCE: washer won't run just makes humming sound
hi the fault may be down to the brushes on the motor
regards
shaun
Posted on Nov 27, 2011
Volvoxc70 doesn't start when i push in the button and then apply the break, after a few times it makes a clicking noise and then the noise stops. still doesn't start. am i actually trying to s
insert the key into the slot then step on the brake and keep it depressed, then push the start button. when it starts to crank release the button.
Feb 24, 2013 | 2004 Volvo XC70
I have a 1994 Chevy Silverado and every time I turn on the ignition, the knocking noise begins from under the dash somewhere. If I remove the fuse to the a/c/heater it doesn't make a sound when I
Try starting the truck so it makes the noise.
Then switch the air control to "fresh".
If noise stops, it is probably the motor that closes flap to recycle the cab air.
It would be found under the dash, under the glove box, & would need to be replaced.
Sep 20, 2012 | Cars & Trucks
The motor runs on my Singer Merrit 8734 but the needle doesn't move.
if you have to undo the clutch to wind the bobbin, then try undoing the clutch again & then retightening the clutch & see if that helps & if it doesn't help the machine needs to be checked
Mar 26, 2012 | Singer Merritt 8734
99 mercury cougar replaced power window motor and switch window still does not work
That doesn't seem possible does it ?
You remove the inner door panel
You think the motor may be bad,so you unplug it,
knowing it is a DC Motor & can be hooked up either
way & will run in either direction
You put 12 volts to it. Doesn't work ,sounds bad,you
install a new one
Now you need power from the switch to run the new motor,
so you work on that
The switch can be disconnected & tested with an OHM Meter
& if worn,you replace that
You checked the fuse before you started & knew that wasn't an issue,
because all the other windows worked
So what did you mis ,short of having no wiring diagram, to make
things a lot easier?
Aug 04, 2011 | 1999 Mercury Cougar
My Maytag Dryer won't start. Mod.# MDE3000AYW . The on button makes the right noise like it is going to start but nothing happens. Sometimes I get lucky and it will start but most of the time it just...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 05, 2011 | Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
When my truck gets hot it doesn't want to start. Sometimes if you wiggle the key it will start, but when it doesn't start, it makes a clicking noise.
the clicking noise is most likely coming from the solenoid on the starter motor, the solenoid is like a big switch with contacts inside of it,when you turn the key to start the engine these contacts come together to transfer the power to the starter motor,if the solenoid can't be taken apart & the contacts cleaned or replaced it will have to be replaced.......hope this helps....cheers
Jun 15, 2011 | 1991 Toyota Pickup
Heatman - you comments are always dead on. You've help me extend the life of my dry twice. My current problem is this: When starting the dryer, the drum will not rotate, and the motor makes an...
it could be the extra weight on the motor and the motor is bad,try this,open the door,push the door switch in with one hand and spin the drum with the other hand and have someone push the start button,if it runs and most of the time it does because you're helping it along you need a new motor.one more thing,if the filter is in front,remove the duct that the lint filter slides into and spin the drum,if the blower wheel moves with the drum you have a bad motor,if it doesn't you have something stuck in the blower wheel and it jams up the motor because it's attached to the motor shaft.
Jun 10, 2011 | Dryers
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
