Question about Disney Tigger from Winnie the Pooh Plush Backpack Orange Black Stripes
How do I change batteries in singing tigger. I can get to the battery compartment but can't figure out how to open it.
This is the singing tigger. I can get to the battery compartment but don't know how to open it.
  • Irene
    Irene Nov 06, 2014
    This is the 12" Disney Jointed Plush singing Tigger.
I have a 5 ft animated singing bear that will not dance
have you checked the batteries are good..
if the batteries are good then you may have to open it up and check the little gears inside.
Dec 09, 2016 | Bear Toys
Animated singing bear stopped working
1.check and make sure batteries are all good.
2.check and make sure batteries are making good contact inside.
3.if the above is ok then you might have to open it up and to check all the little gears inside are working.
Memory Card/Battery Compartment won't open
In General... You need to slide something first and then open the door. Please looks at your manual.
Jul 24, 2017 | Nikon Coolpix S30 Digital Camera White
Battery compartment stuck
I think you should take it to the camera expert who will open it safely and fix your problem.
Jul 15, 2013 | Nikon Coolpix S30 Digital Camera White
How to repogram my magic sing
I can reprogram your magic sing,first I want to know the model.Just post the serial number of your unit.Its in the back cover of song chips compartment.
Jun 28, 2012 | Magic Sing Along Consumer Microphone
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Jan 08, 2012 | RCA DIRECTV Satellite Remote Control
I need to install a 9v battery in my Kenmore Elite upright freezer and I don't know where the battery compartment is.
Please expalin to me what this battery powers, i have been a appliance repair technician for over 30 years and have NEVER seen a battery used to power any component, i know manufactures come out with new stuff all the time so i would like to know what this battery does
Jul 23, 2011 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Battery discontected. Stero now does not operate. Need stereo code. Hyundai Sante Fe 2005 VIN: KMHSC81DR5U900169 Thanks
I don't know how much luck you will have, but open the glove compartment and look all around for a little sticker, possibly white. It should have code. A lot of vehicles that needed codes were factory installed with a code stuck inside the glove compartment. If there is no code in sight, I would suggest calling your local Hyundai dealer for possible location of the code or bringing it in for a reset. Hope this helps!!
Apr 15, 2011 | Car Audio & Video
How do you change the batteries in BUzz?
The compartment for the battery is located at the back of buzz. You have to unscrew using aa small crew driver to open the lid before cahnging the batterie.
Nov 13, 2010 | Thinkway Toy Story Buzz Lightyear Space...
How do you replace the battery - the compartment seems to be sealed
The compartment is glued shut. If you do force it open, you'll find that it is empty. No batteries have been wired into the battery compartment. It must have been used in another model - but not this one.
Feb 21, 2010 | Mattel Barbie 2008 Glamour Jet Plane...
Disney Tigger from Winnie the Pooh Plush Backpack Orange Black Stripes Logo
458 people viewed this question
Top Disney Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Disney Baby Gear Expert? Answer questions, earn points and help others
