Question about Cooktops
When I click the "on" button I get "L" in the 4 LED'S and then i get an ERROR, what can i do to fix it
Did you fix the LLLL error on the HOB as i want to know how to fix mine, its giving me the same error..
Thank you
markanthony.schwartz1@gmail.com
Posted on Nov 10, 2014
Hi weve just moved to new house pre installed Viceroy electric hob when switch on button it gives L code for all 4 rings when i press and hold the on button it flashes error where L was?? help!!
if it is a new house check the kitchen drawers for a user manual for all the installed equipment
If you can't find any ask the builder /retailer for them
May 26, 2016 | Cooktops
My Kitchenaid cooktop is not working, but is beeping. How can I turn it off?
Have u tried unplugging it for about 10 minutes then plugging it back in? Sometimes doing thus can reset it. It is only a quick fix and a qualified serviceman should called to completely fix the problem.
Nov 27, 2014 | KitchenAid KECC607BSS 30" Electric Cooktop...
GE PRIFILE STOVE TOP KEEPS CLICKING AND THE INGITE KEEP GOING OFF ON ALL 4 BURNERS...HOW DO I STOP IT FROM DOING THIS.
Hi pauliepaul22,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | GE Profile JGP636 Gas Cooktop
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
F2 error after oven cleaning came across my display. I had to throw the breaker. Is this something that can be easily fixed?
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Mar 09, 2010 | Jenn-Air Cooktops
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
ERRORS on Electrolux Icon 30'' Induction Cooktop
Call Electrolux or go to their web site and explain the problem there tech department will be able to tell you if you need a service call or can fix yourself.
Oct 03, 2017 | Electrolux Cooktops
Keeps clicking after lit
your ignition button is sticking down after you press it to light the burners, give it a few taps and clean underneath the button.
Aug 23, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Ignition stays constantly on, How to fix it or shut it off
its a gas cooktop it has to be plugged in somewhere op e the cabinet and unplug it. possible that the electrodes got wet and click from a false sense of continuity, after being unplugged overnight that will sometimes be enough. you also might have a bad start switch on one of hte burners causing the machine to click automatically. try unplugging over night first
Mar 11, 2008 | Maytag 30 in. CSG7000 Gas Cooktop
Cooktops Logo
173 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
