Question about Saws
What models of jigsaw blades are suitable for cutting wood using a Black & Decker DN31-H1 Jigsaw?
I have inherited an old, working B&D DN31 Jigsaw but have no blades
  • 9,587 Answers
Blade can be had at any hardware store or home improvement store. There are a lot of wood cutting blades available depending on the hardness of the wood and how thick the material is
Posted on Nov 06, 2014
4 Suggested Answers
  • 7 Answers
SOURCE: I bought a used black & decker jigsaw no. 7548
several methods 1) turn collar near top of blade. spring return. same in reverse to insert. 2)Older type may have spindle screw which draws up collets to clamp blade. access to screw may be through body directly over blade shaft. thats all for now.
cheers
Posted on Aug 27, 2009
buffalonyman
  • 1865 Answers
SOURCE: I do not know to use the black and decker jigsaw.
Draw the circle pattern on the wood where you need it. Drill a 1/2 or 3/8 inch hole inside the circle, near the circle line. Insert the jigsaw blade into the hole and start cutting, following the line.
If you have the scrolling feature on your saw, don't use it, lock the scroll.
Posted on Sep 20, 2009
SOURCE: Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Posted on Apr 24, 2011
I have a black and decker jigsaw that the plate you put on the wood moves and the cut angled and I do not it to?
Hi John:
These saws are usually really reliable, and SOLID.
I'd suggest that you UNPLUG THE SAW and then explore a bit. Look for loose bolts at the pivot points, or possibly a poorly fitted bolt. If this is your saw that you have had for some time, you should know what maintenance has been done that possibly caused this problem.
Oct 03, 2015 | Saws
When cutting straight with my jigsaw the blade floats even though it is in the lock position
There is a speed and angle ratio that must be observed . Depending on the density of the material and the thickness. The shoe plate can be raised or lowered to assist with the forenamed floating condition. Proper blade selection and sharpness is essential.
With thick materials pushing the blades design, speed and force must be regulated through patience to provide the accuracy you demand. The complete blade system is another part of your investment . Understanding what and when can overcome fast if problems arise. Assuming all of this is in your tool box. I always have been taught. Only adapt when all reason is exhausted.
The last part I have had happen is vibration and tool integrity. Maintaining a tight fastener system all over the tool by lubrication is paramount from use or lack of it. Preventive measures spot stuff from happening when you are making the million dollar cut. But we all know that. Daily or startup practice. Just like stretching before playing, a great coach takes the time to do it for their selves too.
There are six JS700 models. Here is a place for parts should that arise Black Decker Jigsaw Replacement Parts Repair your Black Decker Jigsaw... . Furthermore, here is some words for those who are new at the application. Take a look. How to Use Jigsaw basic. This next look in video instruction is thorough and shows intermediate techniques with some experienced foundation. How to Use Jigsaw produced by skill. The Woodworker Journal places the top six picks side by side in the last video offered Top Shelf Jigsaw Review . There is one called a "Mafell" which has a so called perfect orbiting system, which some make it, the straight cut King.
I took the time to do this on the first day of summer. There is lots more to discuss. I think you have the most versatile easy to learn tool in your shop. I am almost sure you think so too. Keep humming. Fare. Well.
Mar 28, 2014 | Saws
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
I need to use my late husband's jigsaw but can't get the old, bent blade out. How do I do it and which blade do I replace it with? I need to cut a few cms off the width of a kitchen worktop. I...
Hi Jen,
It depends on whether you have an older or newer model jigsaw. Bosch makes the newer ones with a button you push that will release the blade.
On an older jigsaw, look at the handle from above the jigsaw directly in line with the blade. You should see a screw in the top of the handle. Use a screwdriver and loosen this screw, don't remove it, and when the screw is loose enough, you'll be able to pull the blade out. When you put the new one in, slide it in the slot until it seats.
A rule of thumb is to use the blade with the wider gap and larger teeth on wood, the smaller teeth on metal. Most blades will say bimetal on the metal cutting blades.
Now, the courser the teeth the rougher cut you'll get. So, if you want a nice cut, don't use the blade with the largest teeth. Move down to the next largest.
I don't have a Bosch, so am not sure which codes are for which blades, but you can't go wrong if you go by the size of the teeth.
You didn't say what material the worktop is made of. If it's wood, the second largest toothed blade should be fine.
If you've never used a jigsaw before, I could suggest a couple tips that would help you get a nice job done.
First, put a piece of painters tape or masking tape over where you will cut, draw your line and go easy. The tape will keep the blade from giving you a roughed up top edge.
When you get near the end of the cut, hold a piece of scrap wood flat against the back edge to prevent tearout.
Also, let the saw do the work, don't push it.
Hope this helps, If it does, I'd appreciate a 4 thumbs up, Thanks,
Handie Andie, "woodworker by night"
May 24, 2011 | Bosch Garden
How do you put a new blade into a Black & Decker JS4000 Type 1 jigsaw
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
Hope this helps.
Mar 06, 2011 | Garden
How do i remove the blade on a black and decker U255S Jigsaw
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
Jan 17, 2011 | Black & Decker Black Decker Orbital...
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
Sep 20, 2009 | Black & Decker Saws
Blade misalignment
The 1590, like several Bosch jigsaws, has a selector switch to choose the type of cutting action. You have to choose the appropriate cutting action, either straight or oscillating, to accommodate the material you cut and the blade you cut with. For instance, if using a very slender blade for clean curved cuts in wood, a slight oscillating motion ( setting II or III) reduces friction on the blade.
If you choose the straight cutting action you get maximum accuracy, but drastically increase the friction because the blade is held firmly to the roller bearing.  A slender blade can handle that for brief periods, (say... less than thirty seconds) in soft, thin wood with a straight cut. In hard woods or engineered wood products ( plywood, MDF etc.) the thin blade will heat up and bend.
You can reduce friction by choosing an oscillating cutting motion, or you can use a larger, sturdier blade. The "Aggressor" blades do not cut as smoothly as the "clean" blades, but they cut faster and are stronger. To cut thick wood ( 4x4 ) or a long cut in engineered material, that is the blade I use. Select number III or number II for 'type-of-cut' and use a bigger blade. See if that stops the "bucking."
Mar 24, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Saws Logo
480 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
