How can I clear the SDM that appears on my Phillips 22 inches hotel lcd TV
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Posted on Nov 06, 2014
zabolyx
  • 38 Answers
SOURCE: TV Wont turn on blue flashing light when plugged in
Your TV has most likely come into contact with a static discharge. Don't fret it might not be damaged.
My Phillips TV I had came with a built in defense of sorts. The system will shut down and flash the power light as a warning.
Unplug you tv for 5 - 10 minutes and then plug it back in. Give it another try.
Posted on Apr 01, 2009
SOURCE: my 22 inch lcd tv 720p does not receive digital signals
how much is it to get the screen of a 22 inch tv fixed
Posted on Jul 07, 2009
maatmartin7
  • 1210 Answers
SOURCE: my 42 inch lcd phillips tv turns on and of by its self and freeze
If it is still under warranty address this. The problem is the signal board. The one with rca jacks and RF connectors.
Posted on Aug 19, 2009
dave1645
  • 834 Answers
SOURCE: chanels missing on freeview
rerun setup and they should be back
Posted on Dec 01, 2009
  • 17 Answers
SOURCE: Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Posted on May 13, 2010
How can i unlick philips hotel tv 32hfl5662l/f7
How to switch your hotel Phillips 32HFL5662L/f7 to HDMI if you need to.
(I'm stuck in St Johns, Newfoundland, miles from the downtown....I must be bored)
1. You will need a serial DB9 M-F cable, your PC with a serial port and a terminal program like Hyper Terminal or Putty
2. Set your baud rate to 115200, n,8,1
3. Unplug the AC adaptor connecting the little smart box on the back of the TV. The TV may plug into this adaptor as well, so just plug the TV back into the wall. If you do not, the LCD TV will try to switch back to cable after you select HDMI.
4. Power on the LCD TV and you should see data on the PC screen in readable text.
5. You must send a carriage return after each command <cr> (the enter key on your PC)
6. Use only small letters (no caps)
i - info
u,d,l,r - Up, Down, Left, Right
p - PIP window toggle
To set to HDMI use the following sequence:
i <cr> (menu)
d <cr> (down)
d <cr> (down)
r <r> (right)
then use 'd' and 'r' to select the right input
Jun 13, 2012 | Philips Televison & Video
17" Sony SDM-S74 goes blank after 1 hour
Here is my possibility.
Sorry to be the bearer of bad news but the fact is you have a very old monitor. My research tells me that it is almost 10 years old.
The obvious problem and the one most likely is that the power board inside the monitor is going. It is common in LCD monitors of this age. Do yourself a favor and junk it and replace is with a new larger better monitor. They are so much better these days and so much much cheaper.
You can get a 22 inch wide screen monitor on Walmart.com right now for $104.00 and pick it up at your local Walmart with free shipping. Not advocating Walmart necessarily just pointing out. Recycle your old monitor responsibly and pick up a new one. No matter how cheap it is it will be better than what you have now and your current monitor is not worth a technicians time.
If you don't have the money for a new one go to your local thrift shop and get a working 17 inch for $20. Good luck.
Walmart V7 22 LED Widescreen Monitor Black
Nov 02, 2010 | Sony DELUXEPRO SDM-X73/B (Black) 17" LCD...
I need the code for polaroid tv with asda remote control model no:urc20-d1f
I just bought a Polaroid 22 inch LCD DVD Combi,, I struggled for hours trying to find a code online,, and eventually researched that my Polaroid TV is made by Phillips,, I entered a Phillips 4 digit code (0081) and it worked.. I also found this link very helpful,, I used the 4 digit code routine. http://www.rtv.co.uk/remote_codes_for_sky_dig_remote.htm
Oct 14, 2010 | Televison & Video
I suddenly get an Information Box stating Model SDM-HS95 and a serial number on the monitor. Does this mean I need a new monitor?
You are precisely right. This happens in Sony models. Have expirienced a lot of this problems relating this issue and all of them have been on Sony and Viewsonic LCD 19" and 22".
Sep 01, 2010 | Sony SDM-HS95 19" LCD Monitor
Can not program to my tv or sat or pinneer eqp.
your tv is in hotel mode. setting menu is disabled, try these universal steps
1st power off tv
2nd power on and press a key, while power on and release key. When is the right combination, appears setting menu and change from hotel mode to normal mode.
Jan 16, 2010 | Sony KDF-E55A20 55 in. LCD Television
Can a flat screen TV with ASC tuner pushed inside be repaired?
sue_shellenb,
I am an installer for a nationwide big blue store. The inputs on the back of tv's are fairly fragile. In my opinion, if the tuner to tv interface is damaged, ("In the process the ASC tuner, or internal tuner, was pushed back into the TV and the technician said it couldn't be repaired.") it probably is not repairable. Or at least, not economically repairable. Cheaper to replace the whole tv.
On the up side, $850 is pretty cheap for a 47 inch flat screen.
Apr 05, 2009 | Protron PLTV-4250 42 in. LCD Television
How to connect speakers to wharfdale 22 inch digital lcd dvd combo tv
please specify the exact model number of your "wharfdale 22 inch digital lcd dvd combo tv."
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division
Sep 23, 2008 | Televison & Video
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Bush 22" LCD TV
Hi.
What is the TV model number ?
Nov 29, 2007 | Bush 5693D 24" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
