Question about Saws
I HAVE ACRAFTSMAN 351217880 JOINTER it seems to cut more in the middle of the board. what adj do I have to make could not find answer in the manual
I have had this for years but just started to use it for small work after truing on table saw I use the planer I use about a 1/32 cut. when done it seems to have an arch in the middle. do I need to adjust unit or is this just operator error
  • 84 Answers
Sounds like you need to replace the knives in the jointer.
Posted on Jan 08, 2015
rowdy45176
  • 2176 Answers
SOURCE: Table saw won't turn on.
that reset is breaker and I would think that it should click when reset. I looked at a breakdown and the part number for the breaker is OLSL list 2.16 and they are in stock at Searspartsdirect.com If you have a volt ohms meter I would check the electrical starting at plug end of cord thru the breaker. Make sure you unplug tool before attempting. I would also take a look at the brushes for excessive wear and sawdust buildup. Let me know if I can help more
Posted on Jan 19, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
protek480
  • 1723 Answers
SOURCE: Table Saw Craftsman 113.299410 Manual
Here ya go...
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0060111.pdf
Posted on Sep 22, 2009
VtToolMan
  • 704 Answers
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
My outfeed table does not run level with infeed table . How do i adjust?
The most important part of the jointer is that the cutting edge is perfectly level with the out feed table, then, bring up the infeed table, with straight edge on rear, make all adj necessary to get these things lined up flat, not level, but flat, straight, even. Then it will cut perfectly flat and even. no snipes,. Hope this helps.
Feb 05, 2012 | Delta Masonry Tools
How do i set knifves in wards powr-kraft jointer mod.no. 2508a
Lower the in feed table to keep it clear of your work, hold a straight edge on the out feed table, both sides, adj the knives to just touch the straight edge, both sides the same, all knives set the same, should work like a charm, do not answer the phone while you are doing this. check all jib screws twice to make sure they are tight. Hope this helps.
Jan 28, 2012 | Delta Jointer Blades 6 Inch Fits , Jet...
I cannot level the tables on my jointer. When I place a level on my tables,the front of the in table is about 1/4" low. how do adjust it? Or better yet where can I geta manual?
Please go to this link, download the instruction manual, then read and understand it before using your jointer. Incorrectly adjusted, even correctly adjusted, jointers can be dangerous tools, and failure to heed the instructions can easily cost you the loss of a fingertip or worse. Only when properly adjusted with the jointer be of any worthwhile use, anyway.
For more detailed information and numerous good articles with details on how to tune and use a jointer, search google for "jointer tune up".
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 06, 2011 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Re: Delta 6" shopmaster bench
It might seem obvious, and no doubt you've long since resolved this question, but was it possibly a breaker that threw due to an amperage overload on the circuit the jointer was plugged into?
The online manual (available here) takes pains to make sure the receptacle the jointer's plugged into is well grounded and any extension cords are of sufficient guage.
Assuming all that's in order, I guess you could bypass the switch to check to see if it is in fact at fault. Replacement parts are available from the same link above.
Jun 04, 2011 | Delta Masonry Tools
My Delta T360 jointer gauges the end of the boards when I run them through.
Check to see if your blades are set to the same depth as per your manual. Also you should only be taking off 1/32" at a time for a true cut.
Apr 20, 2011 | Delta Masonry Tools
Jointer blade installation ?.......model 103.21820..... spacers ? ....blade holder? when making a pass ,the part being machined bumps into the outfeed table
YOu have the infeed table set far too low, and/or your knives are not set even with the height of the outfeed table. You should very rarely need to take a pass of more than 1/16 th of an inch on a jointer, unless the wood you're jointing is very rough cut or cupped/warped.
Please also see the answer given in this article for information about where to download a user's manual and find information on using and tuning up a jointer.
Mar 14, 2011 | Masonry Tools
My thickness adjustment only adjusts on one side.
As it should and is meant to. Please read some articles about the proper us and adjustment of your jointer before you use it, as improper use can result in serious injury. See here for starters.
If it is not cutting properly, search the owner's manual or online for jointer tune up and maintenance.
Good luck.
Feb 24, 2011 | Masonry Tools
Manual for Delta Shopmaster 6" Jointer
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number. It will take you to another page and click on the first JT160 and when it changes screens click on the instruction manual, I had to click on it a couple times to open it but I did look at and it is about 48 pages long. Let me know if you have any problems and I will check further
Apr 04, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Need manual for Jointer
Go to this link and you'll find a complete parts diagram, list, and pdf manuals for your jointer.
Dewalt service net
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Jointers How does it work?
If stock doesn't fit on a stationary machine jointer, then you might consider hand planing. I know that this ideas sounds intimidating, but there is sometimes a time when hand tools can make quick work of things. Truing up large stock is one of those instances - especially in cases where this is wind or twist in stock. Stationary planers won't fix this without jigs, and most jointers can't handle larger stock.
Aug 27, 2008 | RIDGID Featherboard
Saws Logo
79 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
