Question about Fisher and Paykel Washing Machines
Gw11 stops mid cycle and beeps and lights 2 and 7 are lit up anybody know what the error code is
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 66 Answers
Is it model GWL11? There is no model GW11. On most other models that code indicates there is a fault in the water pressure transducer which measures the water level. Unfortunately the motor controller module needs to be replaced.
Posted on Nov 26, 2014
  • 73 Answers
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Posted on Apr 29, 2009
  • 3741 Answers
SOURCE: Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Posted on May 05, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Sears Kenmore HE3 Error Code F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
  • 99 Answers
SOURCE: error code F11 washer stops mid-cycle
The F11 code means that communication between the CCU circuit board at the top of the machine and the motor control circuit board at the bottom of the machine has been lost. The problem most often found is cold solder joints on the CCU board that make and break causing the F11 code and sometimes an FdL code. To fix this you need to remove the CCU circuit board at the top of the machine and have the larger solder points of the relays and the spade connectors resoldered. If your not to handy with soldering you could just print out this response and a good appliance repair shop should be able to help you out. Good Luck.
Posted on Dec 31, 2010
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Our 2 draw dishwasher stops mid cycle once or sometimes several times. The red light comes on and it bleeps until we press the start button then it will continues the cycle.
The red light and beeping indicates a fault. The fault code number will be indicated in the display or by other LEDs being lit. If you post back with the details of the display we may be able to help you.
Jan 25, 2015 | Fisher and Paykel Dishwashers
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
The machine stops on spin cycle and beeps when it is empty.
Hi just read your posting.Now when the machine is beeping an error code will be displayed.If your machine has an LCD display it will appear in it.If your machine has no LCD display then a series of lights will light up when the machine is beeping.These lights that are lit when the machine is beeping will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping, is it the 1st and 3rd or the 4th and 7th ---etc---?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 15, 2010 | Fisher Paykel EcoSmart GWL15
Hi, i have an MW511. All of a sudden it keeps stopping mid cycle with 2 red lights coming on and beeping like crazy. I have re packed the machine, a few times, so its not un balanced, also reduced the...
Hi just read your posting.Now the lights that are on when the machine beeps will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine stops and beeps,Is it the 2nd and 5th or the 3rd and 7th ---etc---?Now to fix the water coming out of the hot hose as the machine is filling just fold the hot hose in half and tape it in this position.This will stop the water coming out of the hose.Please reply with additional information on the lights and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher/Paykel WA37TG1 washer. goes through the wash cycle and the rinse cycle. stops at spin cycle and beeps. lots of suds left on clothes. have unplugged and let sit and start again. this got me through a...
Hi just read your posting.Now when the cycle beeps a series of lights will light up indicating an error code.The lights will be in a row of 8 lights.Starting from the left to the right which lights are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc----?Or do you have the display model and an error code is on the screen?Please reply with the additional information on the questions and I can help you further.
Jul 20, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
Washer will not go through spin cycle just puts water in tub then will constantly beep
Hi just read your posting.When the machine stops and beeps an error code will appear.In the models with an LCD screen it will tell you what the code is.On machines without an LCD screen a series of lights will light up. The lit lights will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine beeps?Is it the 2nd and 4th or the 3rd and 6th ----etc----?Please reply with additional information on the error code and I can help you rectify this fault.
Jul 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
