I have a problem with my prosonic .. when something is white the screen makes it black,
    Top Expert:
  • Televison & ... Master
  • 75,157 Answers
TRy a reset to this tV, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 06, 2014
  • Dawid Puterko Nov 10, 2014
    Thanks !!
    I'll try it .. but now the tv. Is working.
    For like 5/6 days so i'll se if this will keep going and when this problem reapers again i'll do the steps ! But thanks !! :-) sory for my English
I have prosonic tv.is in stanby child lock it can be turn on.what can i do Now
Write your answer...how do I remove prosonic child lock it asking for password and don't have d ideal at all
Oct 28, 2013 | Prosonic Televison & Video
Green and blue faded
Some of these had bad picture tubes--(model indicated here uses 3 tubes)
Simple test is go to a black and white channel and turn color to zero= is the screen black and white or some other color?
Also go to a unused video input and look at screen=all you should see is black screen with the input number in green= any other color and something may just need to be adjusted.
Apr 15, 2012 | Sony KP-65WV700 65" Rear Projection HDTV
Hi i have a prosonic television and i want to play my computer but i am not sure how to find the AV button?
first make sure you`ve connected the AV cable from the tv to the pc and check carefully in the remote and press the tv button if AV is not indicated
Sep 16, 2011 | Prosonic Televison & Video
Need to by a new control remote
Hi you can get a 'One For All' remote to cover prosonic models and the Essence version covers 17 prosonic models, getting an original remote seems pretty rare.
They are available from Argos if you are in the UK ----> Click Here For Link
Amazon do a good range too.
Hope this helps , please let me know how you get on.
Good Luck
Midge.
Feb 10, 2011 | Prosonic PLTV-30 30 in. HD-Ready LCD...
Hallo. I have a Prosonic TV type LC-27M65 that will not switch on. The red control light for remote is on. The yellow light indicator for current is off. Although TV is connected to net for power, the...
It is possible that your TV has encountered a fault in the power section possible a short in the drive power section. hence on powering the power sully working OK is switching the secondary power to the main board but this short is taking in more current than specified. the feedback of this is read by the SM unit to shut off the power to protect the supply. Hence you will have to probe into the sections to find this short, perhaps a HT drive transistor or the HT transformer or capacitors. If will be easier to check the continuity with a meter. Please attemptt only if familiar otherwise take help. Disconnection of the shorting section will switch the power, replace teh component in question. Hope you try. Good day
Aug 16, 2010 | Prosonic Televison & Video
On the rear of a Prosonic TV there are an audio out, coax connection for an amplifier. How can this plug / connection support an amplifier with a stereo signal? Make: Prosonic Model NO.:PBT-26001
It's a digital signal, basically, it's sending left and right out as 2 seperate frequencies and needs to connect to a suitable amp to "decode" the signal.
May 18, 2010 | Televison & Video
Screen on all games is blurry. Just started
make sure its not your tv.there might be something wrong with your xbox or you did something in the options menu that messed it up
Jan 20, 2010 | Microsoft Xbox 360 Console
When an electronics panel has power fualt which machine
USE A MULTIMETER TO CHECK YOUR VOLTAGE, MAKE SURE TO CHECK ON DC RANGE, AND THE OUTPUT SHOULD BE IN BETWEEN 7-12 VOLTS DC-----WWW.FLUKE.COM
Oct 16, 2009 | Prosonic PDS-758-LP Portable DVD Player...
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Televison & Video Logo
Top Televison & Video Experts
